Results 1 to 10 of 10
    Default where is Inertia fuel shut-off switch
    Hi, i have 2016 mustang ecoboots, alternator is ok, battery is ok,
    is like gas stop, i did see something in google about inertia fuel shut-off switch
    where is this locate in the car.
    thank y
    Portland Oregon
    Not the correct forum but check your owners manual. It should tell you where it is.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    Jul 2012
    Georgia
    I can tell you the shut off in a 1984 model is in the trunk above the driver's side wheel well. After I got rear ended, the car wouldn't start, and the cop who was helping at the scene used to drive a Fox mustang cruiser, he actually knew where it was. I both learned something about the car, and lost it in the same night!
    ok, thank you
    i check it and not found, google or another data engine not have information with 2016.
    thanks
    I believe Ford did away with the fuel pump inertia switch on the newer model vehicles. Virtually everything is run thru the different computers/modules.
    It is possible you have a bad fuel pump, or it could be related to the anit-theft system as to why you can't get the vehicle to start. If you have the owner's manual I would recommend checking that for help. Good Luck!
    Yes, manual not help to much,
    i think problem is about anit-theft system, fuel pump or some fuse like Fuel pump relay, Starter motor solenoid.
    thank you!!!
    Just checked the shop manual for this vehicle, they don't have a reset switch. The Fuel Pump Driver Module is located under the rear seat.
    Yes, i read that in some google page, but i left the car at the dealer,
    later i will post was what the problem, maybe help others.
    dealer said problem is the fuel pump
    Non-FEP section recommended
