Results 1 to 5 of 5
    Sep 2014
    Freeport NY
    Default 84 5.0 CFI air cleaner gasket
    Anybody know the correct part number for the CFI air cleaners gasket?
    I tried to pick up one at autozone but the Felpro 60038 was too small inside diameter. It was the only part they had in stock.
    I dont mind ordering and waiting I just would like to correct part number if anyone know it.
    Dec 2006
    Middletown, DE
    Ford part number for the air cleaner to carburetor gasket on 84 and 85 5.0 automatic cars is D8ZZ 9654-A.
    85 Mustang GT
    Fel-Pro 60038 is 5.0312" id. For std Holley 2V and 4V carb. Just bought one for mine.
    Fel-Pro 60379 (D8ZZ-9654A) is 5.375" id. Many Ford apps. Assuming this is the bigger one you need.
    Doing a AZ web check, under gaskets, fuel system, air cleaner mounting gasket, both sizes show up.
    Both sizes are listed for 5.0 TBI.
    Freeport NY, Freeport store= none.
    Baldwin and Bellmore stores have them. 516-377-1049, 516-826-2533
    Plus stores in East Meadow, Levittown, Bethpage.
    I got a cfi (carb) rebuild kit from Napa and I’m pretty sure it came with the gasket. I know the carb and cfi air cleaners are different so I would expect a different gasket.
    Every M code CFI air cleaner uses the 5-3/8" 2-bbl CFi flange tangs and as JACook and others have observed, a 1/4" bigger base diameter than the 4V, so it won't fit any 4150/4160 or 4180c properly with out work.
    Every M code 4V HO has the Ford's smaller version of the 5-1/8" Holley 2 and 4bbl upper carb flange, but with a tight twin metal tang.
