Results 1 to 25 of 33
    Default 302 EFI to carb (car isn't EFI)
    So I can't seem to find the answer to my question, every thread so far to me seems to be converting a car that is EFI over to carb.
    I have an 80 4 cyl, and since the weather is starting to get nicer I want to swap it over to a V8. My question is, if the car is already a carb, can I just throw a carb intake on a newer 87-93 EFI motor and call it a day and will it work? Or is there something else I need to do in order to get it running. I'm trying to find the cheapest and easiest way to get the car to a V8 for now because the way it is isn't unbearable to drive and doesn't inspire safety or confidence.
    Would it just be easier to get an EFI motor and convert mine over? Or is it safer and cheaper just to stick with a carb for now to get the car with a running V8?
    Thanks!
    Yes you can. The distributor would need to be changed to a 85 5.0 (carb and roller cam gear) and add a timing cover with provisions for a mechanical fuel pump and drive eccentric.
    85 GT - owned since 87
    Pretty much it
    nothing else comes to mind off the top of my head
    i mean you have motor mounts and crossmember and exhaust to contend with. If you want specifics we are happy to deep dive.
    You didn’t mention trans or rearend or anything
    Thanks!
    So as long as I find a distributor from an 85 mustang specifically that will work? And I'm assuming I can get a timing cover from any early model 302?.
    So for the rest of the car, my plan was to get a wrecked 87+ fox and just swap everything over as a starting point (motor, trans, rear, etc). I figured it would be much easier to do it that way than to try to piece everything together and have it apart and unable to move. Unfortunately I've never done a job this big before, so I'm not entirely sure how well it's going to work out, but I'm trying to get everything together now so i can make this as painless as possible.
    Thanks again for all the help!
    I’ve done several engine swaps and there’s benefits to each,
    If you get a donor car you have everything you need so converting to carb means buying more parts.
    Remember that the newest fox mustangs are 26 years old so a lot of parts may need to be replaced on your donor engine.
    Unused a high mile ‘87 donor to build my FFR and had to rebuild or replace almost everything, engine trans and rearend rebuilt, suspension steering and brakes were just used for cores. I may have been ahead to buy a lower mile parts car with useable parts.
    If you go with a carb you can use an electric inline fuel pump and don’t have to change the timing cover. This is what I did on my 83.
    The 85 Duraspark manual trans distributor is compatible with a roller cam (steel cam gear). I don't think a EFI/auto distributor is Duraspark, its EEC, and it has a cast gear for a flat tappet cam.
    Quote Originally Posted by AldeanFan View Post
    I know it's more parts, but I'm just trying not to have to deal with wiring up the new ECU to the old stuff. And I know it's going to be old stuff, like I'd probably redo mounts and things like that, but 26 years old is much better than the almost 40 that the car is. I'm going to try to source a carb and find a good distributor to use before I find a car I guess
    Rock auto had a distributors on clearance right now, hard to beat
    I have a Holley 4010 on one of my cars and it runs great and easy to tune, now sold as the summit carb, good carb at a good price.
    Nov 2004
    Chas. SC
    You can run a low pressure electric pump eliminating the need to change the timing cover.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Thanks so much guys, I'm trying to source all the parts together now. Just more of an opinion question, do you guys like the 2 piece eccentrics or the 1 piece ford racing ones? and do I have to change the timing chain to change that or just the dowel?
    Apr 2016
    Sprague River, OR
    If you can find an '87+ v8 donor car, why not just swap it all over and stay EFI? 89+ would give you a Mass Air car instead of the Speed Density. I just finished swapping in a complete '92 donor car into an '80 notchback.
    Join The Conversation
    We’re accumulating parts for a swap right now on my dad’s ‘83.
    I have a complete ‘89 engine as well as a 4bbl intake and carb.
    The EFI works great and is not too difficult to make work, but requires a high pressure pump
    If I convert to carb I still need to deal with the fuel pump but less electrical.
    How hard is it to make all the wiring work? I also know the newer style gas tanks don't fit in the 79-82 mustangs to use an electric fuel pump internally, and I don't really feel like "massaging" the trunk pan to fit since the cars in good shape as it is. Staying carb just seems easier at the moment and I don't have a garage to keep the car in and slowly work on it as I need it.
    Nov 2004
    Chas. SC
    simplest but not the best. just mount a low pressure (3-4 LB) electrical pump in the fuel line near/lower then the tank. One wire ground , one wire to keyed hot.
    Albert Einstein
    Almost "Stock"
    Quote Originally Posted by Airdale View Post
    Not hard if you can read a wiring diagram. I’ve done it twice and worked well both times, but with ‘87 speed density engines.
    "Staying carb" IS easier (and cheaper, simpler, more reliable and predictable, and can be tuned to hand fuel injection an embarassing proper whoopin' in the fuel mileage department). All of your points and reasoning make perfect logical sense for your situation. Don't let fuel-injection cheerleaders make you feel you need to defend what you have already decided to do with YOUR 1980 vehicle, lol. I feel it's a shame to turn a vehicle originally equipped with a carburetor into an inefficient, never-reliable-for-long, inside-the-box, always-more-expensive-to-deal-with, robot. For the most part, I think your original question/s have been answered. Good luck with it.
    Sorry for the probably stupid easy question, but I think I'm going to try to pick up a donor car this weekend, and class has been killing me so I don't have as much time to research this as I'd like.
    Is mounting the external electric fuel pump easier than staying mechanical? What are the pros and cons of it? I'm assuming ease of install (electric) and simplicity and reliability (mechanical)?
    I was looking up how to connect it, but I'm assuming instead of finding a keyed hot wire I can just run a switch to it to manually turn it on and off to save splicing into 40 year old wires?
    Also is there anything I should be looking for? All the crossmembers and mounting points for the rear end/suspension would be the same from a newer car? If this car works out the donor would be a 91 GT with rotted out strut towers.
    Sorry again for the probably super easy and dumb question, but I'm also pretty nervous about doing it since I've never done a job this big by myself.
    Thanks again for all your help!
    Your engine may or may not have a spot for a mechanical pump.
    If the boss is cast in but not open you’ll have to remove the timing cover to mill it out.
    If it’s not cast in then you need to change the timing cover.
    For an electric pump I’d recommend wiring it to constant power through a relay triggered by an oil pressure switch. That way if the engine stalls or in a collision the fuel pump stops.
    Only draw back is you’ll have to crank until it builds oil pressure to get fuel so if the carb is dry from sitting it will take a lot more cranking to get it started the first time.
    Wiring the fuel pump is as simple as running wires from the front of the car to the back.
    For the fuel pump I think I'm just going to wire it to ignition accessory hot (and also put in a hidden switch to kill it regardless if I have to leave it somewhere) and also nab the inertia switch from the donor car in the unfortunate circumstances of a crash. Should I do the oil pressure switch anyway?
    Okay so, here's another question.
    I have the donor car and I started the swap. So far I've only gotten the rears swapped since the weather hasn't been too kind. However, the ebrake cables were cut and I want to get new ones, but I don't know which one to order. Is it based on the rear end? or did different years route the cables differently? Should I be ordering it for a 91 rear end since that's what it is coming out of? or does it not matter?
    I’m pretty sure all drum brake parking brake cables are the same in fox body mustangs.
    So I don't have enough posts to post in the classifieds yet, and I haven't started a build thread yet, so I'm just posting here (sorry if that's wrong) to say that if anybody needs any 4 cyl parts please let me know as soon as you get the chance, otherwise it might get scrapped. I'm going to keep the things that I think are worth it, but if It doesn't seem like it's useful I'm just going to leave it in the donor car when I drag it to the yard.
    Jul 2009
    Chicago, south subs
    Inertia switch is a good idea in case of accident. Oil pressure switch probably not necessary (in the fuel pump wiring, at least). With a carb, the engine would keep running until the fuel bowls are empty even with no oil pressure and being in an accident doesn't necessarily mean the engine will stop. If you want the engine to shut off with no oil pressure, wire the switch so it cuts off the ignition.
    I just want to say thanks again for all the help already.
    I know it's been a while, but the swap is very much underway (I'm almost done), and I'm curious as to the fuel pump mounting. I bought a holley blue, and I was going to mount it above the tank on the spare tire wall (I guess that's the word I want). I was told not to do that, so my question is how safe is it if I drill into the frame rails and just bolt a piece of angle iron to it? Also I have a feeling that would get in the way of the subframe connectors?
    Has anybody done that and been happy with it?
    Other than all that I just have to finish rebuilding the carb, hook up the ignition module and coil (which I realize now I didn't have to take out in the first place) and the car should in theory run.
    The spare tire well is a kettle drum but, I have mounted them up on the floor, next to where the filter is on an efi car. Use some rubber to insulate the bracket from the floor and rock it.
    Okay, so please forgive me for being ignorant here, but I've never actually done this before and I don't wanna burn out the pump. You have it mounted onto the floor? I know it says mount below the tank and have it gravity fed, but the lines coming out of the tank are facing upwards, so how would that work? Am I just way overthinking things? I also have a purolator pump (pic below) in the engine bay, but is there an in tank pump on these cars? I didn't think there was but that seems pretty far forward to be a pushing pump
