Results 1 to 13 of 13
Thread: Brake Lights
    FEP User Vettn71's Avatar
    Aug 2016
    North Richland Hills, TX
    Default Brake Lights
    My brake lights have quit. They were working, because the car passed inspection. Itís an 84 GT. Anything besides bulbs or fuse
    TIA
    kJom
    Check your brake light switch. Use a test light and check for power to switch and push pedal down and check for power out of switch. It is located on your brake pedal towards the top.
    1967 mustang coupe -sold
    1967 cougar GT - sold
    1984 Mustang L 5.0L - Totaled
    1984 Mustang GT 5.0L
    2007 Mustang GT convertible ( wifes car)
    1997 F-350 powerstroke
    USMC Retired 1981-2001
    Aug 2016
    Yes, I just replaced the switch. Looks like it’s time to inspect every wire.
    Thanks for your help
    jim
    Ground wires can cause havoc
    Aug 2016
    10-4 to that. Iíll put that on my to do list
    Thank you
    Jim
    Aug 2016
    Fuse is good, but no power to the switch. Any ideas?
    TIA
    Jom
    Portland Oregon
    I’d check your turn signal switch. Brakes lights went out on my 67 when I first got it and it was the turn signal switch that caused it. I believe power comes from there. Good luck to you.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    Aug 2016
    Thanks. I replaced everything else.
    Jim
    Aug 2016
    I’ve got an 86 service manual. Not sure how close it is to an 84. It shows the wires from the brake switch going to a 14290, which I guess is in the steering column?
    jim
    Aug 2016
    My flashers work, I have power at the fuse. I have turn signal/multifunction switch ordered. What else can I check?
    TIA
    Jim
    Aug 2016
    Tigger and all, thank you for the assistance. I followed Tigger's advice and bought a turn signal multifunction switch. I now have brake lights!! Why Ford would run this through the trun signals I can't figure, but they did. Pretty easy fix. I removed the steering column covers and everything was right there.
Size:  102.8 KBName:  IMG_0096.jpg
    Aug 2016
    The most difficult part of this was getting the turn signal lever out. It's held in by a retaining pin that should release when it's pulled. Mine would not release, so I wound up taking the old switch apart
    Jim
    FEP User
    Oct 2017
    south-central WY
    If the car uses the same bulb and filament for brake light and turn signal, the brake light circuit has to run through the turn signal switch or the rear turn signal would not flash when you hit the brakes.
