Hi
I am running a set of worked 351W heads that have 13/16 (18mm) spark plugs. I have autolight AP 45 plugs,
an wonder if there is a better plug to use.
Thanks,
Ed
Hi
Thanks,
Ed
Hi How worked are the heads? Still pump gas compression ?
Best thing would probably be to 'read' them after being run. That can help you decide if the heat range is correct, etc.
Depending on the type of 302 or 351w head you are using, from 1974 or up they switched from the 18 mm larger plug to the small 14 mm ones.
Although it has to be pegged, there is an adaptor the FE and Log head 3.3 guys use.
https://brillman.com/product/spark-p...-18mm-to-14mm/
