Results 1 to 7 of 7
    Default T fitting - Oil pressure sending unit
    I have a mechanical oil pressure gauge I'm hooking up, but wouldn't mind for belt and suspenders keeping the dummy light active. I've heard of a T-fitting to do so...is there a PN I could use? Or am I best off taking off the current electrical fitting with me to a Lowes/Home depot and digging around the plumbing section?
    Grant get yourself a Oil Pressure Sending Extensions C2OZ-9B339-A it will make it so much easier to work on. They sell em on ebay and other places to.
    Looks like 'A' suffix is single hole, 'DP' is 2 port?
    Whatever, do not use brass pipe for extension. Too soft or thin in thread area.
    Brass tee ok. Found iron pipe and tees work fine too.
    Yeah, I just went to the hardware store and picked one up with the correct threads as mentioned above.
    Hooker Super Comp Shorty Equal Length Headers
    GT40 heads, Edelbrock 3721, K&N filter in stock dual snorkel,
    Comp cams XE254H, hypereutectic pistons, catted BBK H-pipe, full custom duals.
    3.73 rear. CS5 225/60/15 on 10 holes (street) Federal 595 rs-rr 225/45/15 on 10 holes (race)
    Everything else stock and fully functional.
    Thanks everyone...and good to see you on board here Gary!
    Anyone know what size the fitting is? I tried getting an 11mm, 12mm, 7/16 and 1/2 on it, and the big ones were too big and the small ones too small. Guessing it's like a 15/32"?
    Aug 2009
    Dallas, TX
    Quote Originally Posted by Str8sixfan View Post
    ..1/4"
    Original Member of 'The Anti-Cowl Hood' Club and 'The Ten-Hole Mafia'.
