Hello!
So I am at a stopping point between tinkering and using the search engine. I’ll go chronological order to my stopping point.
I’ve got an ‘86 GT, all stock minus wheels, MAF / Intake & smog delete. I’m trying to get air to blow out of the dashboard vents. In 86 it’s a lever that you move up and down to control the location. Air DOES blow out of the defrost and feet, however once I switch it to VENT or AC - nada.
Did a little searching and vacuum leaks seem to come up but I had no idea where to look.
forum searching brought me to photos of the vacuum tree. Mine is capped off... I’ll supply photos. Further searching brought me to a diagram of the vacuum lines (where they should go) but I have no idea how to read it and apply it to the engine bay.
IF this is the problem, should I get a vacuum line (size?) from the store and run it to where it needs to go and maybe have air blowing from the vents now?
Respectfully,
Casey
