Results 1 to 7 of 7
Thread: Fastener size
    Nov 2014
    Grand Rapids, Mi
    Default Fastener size
    The front nose studs that fasten it to the front fenders, use the same size nuts as the hood scoop, tail lights, etc. I have bought every dang nut from the hardware store, including an M6 1.0 nut from Napa. Nothing fits. Any idea what they actually are? They look like these. Name:  D0DF2087-9661-4F93-8EFA-37E1E54F7353.jpg
    Nov 2014
    Grand Rapids, Mi
    This leads me to believe these old cars have a specific tpi that isn’t available at an average hardware store.
    May 2014
    Royal oak Mi
    Did you try 10-32 10-28 ? I wouldn't think it would be metric for the year but that means nothing
    If you have older body shop near you they probably stock em and will help you out newer cars use mostly plastic fasteners and push pins
    If I recall it's fine thread so maybe even 1/4-28
    The studs are 1/4-20 from the factory. I would bet that you have a damaged thread that is the reason why you can't get the nut to thread on.
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Agreed. In my experience these are 1/4-20 UNC. These should be interchangeable with 79-82 (maybe later) hood scoop and one piece rear spoilers from my limited need to find replacements.
    Jul 2016
    Duncannon PA
    1/4 20. I keep a box of them from Auveco. Ya know. Just in case.
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
    Chase them with a die perhaps
