Results 1 to 6 of 6
    Jun 2003
    Santa Maria Ca
    Default EFI engine test stand
    Anybody ever build an EFI engine run stand using factory type SEFI parts? I’m not too concerned with the stand portion, but more of the wiring aspect. I’ve got all the key parts, including a 90 harness with an A9L computer. Basically everything else I have in triplicate. What is the minimum wiring components to make it all run so I can break in a motor?
    85 Saleen Mustang(s)
    You don't necessarily need everything shown, but here is the basic wiring needed for the SEFI.
    Name:  EFI Wiring.png
    Obviously you could leave out the inertia switch and the self test connector, but not really sure what else you could delete or leave off and not have possible run issues. If you want to just do a break in, then obviously a carb might be an easier setup. If you want to actually test run the full EFI setup, then I would probably wire up everything as it would be in the car. That will allow you to verify and test everything. Good Luck!
    Jun 2003
    Santa Maria Ca
    I like the accurate air/fuel ratios during the vital engine break in period. A carb is easier for sure, but needs tweaking to get running right. I’d rather rely on the computer to compensate for these variables early in the new motors life cycle.
    Jun 2003
    Santa Maria Ca
    Is there anything special regarding the starting system? I plan to run whatever flywheel that matches the engine balance, with a factory bellhousing and a stock starter. The bellhousing will be bolted to the run stand base to keep everything secure.
    Do I just run a battery to a stock solenoid with keyswitch and a negative ground to the stand/block? Is it that simple?
    I saw a box upper a while ago that puts a square carb on top of an 8 port EFI lower. Was pretty cool, would work good for breaking in a motor. Hell - put plate EFI on that and pop it through the hood just for show.
    that would be easy. Mount a tray that holds a gas can high enough to do a gravity feed into an external 1989 f150 fuel pump. use flexible efi hose and -6an fittings from ebay into the OEM fuel rail. You could do the return line right back into the top of the gas can.
    Wiring is ez...ground at the computer, then green plug has a green/yellow wire to fuel pump, then at the brown connector if memory serves is the red/green wire that gets key on power...other then that there should be a ring terminal that supplies the constant power to the harness that goes to the plus side of the battery. Using a 92/93 harness would be easiest because of the build in fuel pump relay
    Jeremy
