Page 5 of 6 FirstFirst ... 3456 LastLast
Results 101 to 125 of 141
  1. #101
    Haha that's my wife's truck... turns out it looks like it's from a 95 cobra as it has the 11.66 in rotors. They are aftermarket i guess since they're not drilled or slotted.
    1984 convertible 5.0 auto.
  2. #102
    This is the pinion bearing out of the rear i bought... good thing I'm paranoid about the parts i buy lol
  3. #103
    Dang!!
  4. #104
    Send it! Lols
    Doubt it has ONE pass left in it!
  5. #105
    Quote Originally Posted by rich75043 View Post
    Stock Cobra and GT/V6 rotors were not drilled or slotted. Look like original or original style replacement rotors to me. Good score . . . Well except for the bearing issue!
  6. #106
    Oh ok i thought i read they came stock with the drilled, slotted rotors. They don't have a part number anywhere on them so im guessing they're replacements? I learn something everyday. Also it had a set of Ford 4.10 gears in it so I'm guessing whomever set it up didn't do their due diligence in the assembly.
  7. #107
    Lordy i hope i never have to do front suspension crap again lol. I now have all new front suspension bushings and balljoints with late model fox spindles, brakes and struts.
  8. #108
    drain plugs on fords strip easy'i think the threads on the plug are too soft.any time I buy a ford first oil change I replace the plug
  9. #109
    Ok..... one common misconception is that oil plugs need to be pulled down TIGHT. They don't. Only about 10 ft/lbs -- thats IT. If they don't seal there then identify the reason they aren't sealing and fix it. Don't over torque the oil plug.
    I had to use a torch and a cold chisel to get the oil plug out on my Sebring one time. I chewed the quick lube place's butt -- absolutely NO reason for a plug to be that tight. I was PISSED. Had just put in a desludge treatment so I couldn't drive it to them and make them take it out.
    Got it out without ruining the pan. Was shocked.
  10. #110
    Same thing for lug nuts. Is there any reason to use a truck impact wrench to put car wheels on? I've requested hand tight and been told, "oh, they have to pop the nuts to be sure." Really? And how do I get those nuts off on the side of the turnpike with the little wrench that came with the car? One advantage to getting heavier in my older years is to be able to put more weight on the breaker bar!
    W
  11. #111
    GDMFC... this stupid speedo won't go in the drive of the tach. Get in the hole... go home... don't you want to go home? Lol it came out easy peasy taco squeezy but now...nooooo. Stupid big ass hands off mine. Ok I'm done.
  12. #112
    Apr 2006
    Dallas, TX
    Did you try turning the lights off?
  13. #113
    ... turning the lights off? Sometimes I'm a bit slow, please explain. Anyhoo i finally got it. The square drive in the housing was a bit crooked and wouldn't line up so i made sure it was centered and it finally slid home. On a happier note i changed my lower rear control arms for some tubular ones and some koni rear shocks. Holy shazbot it rides so much better. One of the rear shocks would compress but not extend so every bump i hit would rattle the whole car. So what's the debate about the rear sway bar? To install or not install? Well hell, the only major mechanical thing i have left is the sn95 cobra 8.8 sitting on my work bench. To install I'll need parking brake cables which lmr carries. Brake line from body to center of the diff. And wheels. Not to mention front rotors from a mark VII. Master cylinder and a P valve. If i stay 4 lug all i would need to do...i believe... is put my drum hardware and axles in and the brake line to the center of the diff. Or i could just say screw it and procrastinate and just do nothing. Leaning towards nothing lol my old ass is so sore from crawling up, down, around and under that damn car.
  14. #114
    Well poop, i forgot about the door hinge issue lol that looks like fun from the videos I've watched about it. Gratuitous pic of Cobra diff included lolName:  20190508_153704.jpg
  15. #115
    Well i finally quit whining about it and just did it lol i know i know the tires are **** but at least it runs and drives and stops lolName:  20190515_161413.jpg
Size:  132.3 KBName:  20190515_201455.jpg
Size:  177.7 KBName:  20190515_201513.jpg
  16. #116
    Apr 2006
    Dallas, TX
    Don't you do your best work in the dark?
    Good to see your progress. Keep it going.
  17. #117
    Ooooh lol told you i was slow sometimes. Funny how that works, seeing nothing and doing your best work. When i was a heavy equipment mechanic it seems like i was always working blind lol. For such big machines you would think there would be plenty of space to work.
  18. #118
    Found a b&m hammer shifter for a song... just a little surface rust as the gates work as they should. Decided a little voodoo electrolysis was in order. Man that science is crazy. The second pic is after about 30 min.
Size:  97.8 KBName:  20190520_185055.jpg
  19. #119
    Magic...Name:  20190520_230855.jpg
  20. #120
    That's awesome.
  21. #121
    Finally sourced the last two gt wheels for Big Jim. Now all i need are the Mark VII rotors from rock auto.
  22. #122
    So i finally got fed up with the stupid rattle in my driver's door and tracked it down. It's the exterior door handle rod rattling around in the push hole or whatever it's called lol I'm guessing there's supposed to be a plastic insert that the rod passes through to prevent the offensive noise but mines long gone. What to do what to do. I used some left over heat shrink tubing i had left over from the wire tuck. No more rattle. For some reason the second pic is upside down. Name:  20190524_133056.jpg
Size:  131.5 KBName:  20190524_133314.jpg
  23. #123
    Well Big Jim is mostly one color lol just waiting on the damn fedex man to bring me my 5 lug rotors...tic toc
  24. #124
    So i came across a bbk catted h pipe for a song so off came the quad catted factory h pipe i had. It's a bid louder i must say.
    https://youtu.be/Cjz01YBQNMQ
  25. #125
    Damnit they got me lol bought two svo rotors and i got them in today. Installed the first one perfect. 15 min and done. Took off my other rotor, cleaned up the spindle to get it ready and lo and behold they sent the wrong friggin rotor. Damn damn damn. Name:  20190530_190112.jpg
