Page 6 of 6 FirstFirst ... 456
Results 126 to 141 of 141
  1. #126
    So my left taillight was faded almost clear on the outside edges and i decided to try and do something about it. I didn't realise they came apart that easy. I'm guessing the po had them apart at some point. I took advantage of the down time with some silver metal hvac tape to line the reflectors and bought some VHT night shades red spray paint. That crap was 15 bucks but did a really nice job.Name:  20190603_113856.jpg
    1984 convertible 5.0 auto.
  2. #127
    I finally received the correct rotor and got all four of Big Jim's feet on the ground. Name:  20190606_192717.jpg
  3. #128
    Sitting on 'er wheels is a big moment! Congrats!
    Just saw the update with the taillights too, looks fantastic! Hooray for a little DIY instead of spending big bucks on new lenses!
  4. #129
    Jun 2016
    Saint Clair MI 48079
    Wow taillights look great!
  5. #130
    Thanks a ton guys. The bigger brakes and rear discs feel a whole lot nicer than it was. Now i gotta do something about the rear bumper cover. I did some looking underneath and the flat piece of metal up top is sagging a bit. Hopefully fixing that and a little heat applied carefully will take out the bulge in the middle.
  6. #131
    So this is what I'm working with... hump back Jim lol.
    So i removed the bumper and decided to try my hand at fixing it, at least making it a little better. The second pic is me putting rivets in between the sagging parts to try and tighten it up a bit.
    Next im tying a little adhesive to stick a backing plate to try and remove the hump under the plate. We'll see. I don't think i could make it worse lol
    At least Big Jim's rear is unmolested under the cover Haha
  7. #132
    Be sure to seal up those tail lights and use some new retainer tabs so they don’t fall off
    Looking good!
  8. #133
    Oh i did. That 3m black weather strip adhesive is some sticky stuff lol i got Big Jim's cover back on. All in all not too terribly bad.
  9. #134
    Jun 2016
    Way better!
  10. #135
  11. #136
    Assuming the top is vinyl, aero 303 would help freshen it up. I use it on all plastic/vinyl pieces. It is not greasy/sticky.
    https://www.amazon.com/303-30306-Aer.../dp/B000XBCURW
    1985 GT owned since new
  12. #137
    Thanks for the info. The top is trashed unfortunately but I'll def need something for the new one when i get it.
  13. #138
    Going to tackle my door panels tomorrow. Got two pieces of thin plywood, some contact cement and i already have staples and rivets.
  14. #139
    Well i got the driver's side done. Not near perfect but lightyears ahead of what it was. Name:  20190621_134840.jpg
Size:  74.1 KBName:  20190621_145707.jpg
Size:  70.2 KBName:  20190621_170542.jpg
Size:  151.8 KBName:  20190621_181319.jpg
  15. #140
    Sweet. I need to do that too.
  16. #141
    Oooh I'm excited, i finally scored those stupid door trim pieces that nobody makes.
