Results 1 to 8 of 8
    FEP User Vettn71's Avatar
    Aug 2016
    North Richland Hills, TX
    Default Distributor GearsM
    I’ve got a 84 GT with the stock motor and Durapark distributor. I’m putting an 85 engine, B cam and a Petronix distributor. My question is can i use the Duraspark in the 85 engine with B cam. I hear various things and would like some real ,information from someone with knowledge.
    Thanks for your help
    Jim
    Best part to grab is a replacement 85 distributor as it has the needed steel gear.
    Any gear 85 matched with a roller cam should work
    Nov 2014
    Grand Rapids, Mi
    My BIL just found out the hard way on his Corvette. It was his step fathers car, that had the engine built by a reputable shop, and his step father had a “friend” finish it off with a carb, and distributor. My BIL bought it from his step dad with about 5 miles on the rebuild. BIL put about 75 miles on it before the roller cam ate through the stock dizzy gear, resulting in a rebuild. These are cases where it’s best to call the cam manufacturer, or read what the cam specs say. But I agree, I believe you’ll need the steel gear.
    Yeah, ignore the cars requirements, just find out the shaft diameter and use the gear the cam requires.
    Buy the plastic gear and never worry again.
    "40 year old beercan on wheels with too much motor" erratic50
    Aug 2016
    So, my 84 non-roller has a cast gear, I guess. To use it with the B.cam I’d need to upgrade the gear to steel or use my Petronix distributor, correct?
    TIA Jim
    May 2014
    Royal oak Mi
    Steel is correct don't use cast on roller cam
    It's not that it's a roller cam it's the helical gear on the cam itself that determines what gear for wear/compatibility
    You can use bronze gear but you will not get much out of it for miles (gear wears to save cam wear)
    Word of caution make sure the distance for set up is correct from gear centerline to bottom of distributor and don't use same roll pin hole
    Call Ford tech or look on there site and only there website MSD was not correct and I was eating gears
    Ford racing catalog has a page published that's very helpful
    If your set up is wrong you will eat gears and all of the material will go to your oil pan and you know the rest
    The cam will pull dizzy gear down by helical gear design and eats gears if not set up right
    Don't be scared it's easy to do just get it right and not sure if your 84 non HO dizzy will work with 85 HO firing order
    HO firing order won't matter. I would go with your stock, after my experience I wouldn't want to gamble on shaft lengths. Just pop off the old cast gear (and save it, they are rare now) and put on the new one. Or, while it is out you can try to verify that any new one you use has the appropriate shaft length and gear position.
