Results 1 to 14 of 14
    Default 2019 - what did you do to your Four Eyed Fox today?
    Me ..... worked on getting an engine nailed down for my 85 Saleen project.
    -- James
    My four eyed foxes:
    "Trigger" - 86 Mustang GT - Black with red interior. 5.0 T5 built as Z. Original motor ~1/2 million miles. 18 yr daily, 7 a toy
    past foxes -
    1989 Mustang LX Sport 5.0 AOD white/tan black top.
    Default ok 2019
    Untarped it. Covered only the greenhouse part.
    Been below zero for most of the week. No garage. In 5 days span, from -40 wind chill to forecast 50 Monday.
    Doors opened fine, no sticky locks. The Ranger doors freeze up with the door seam up on the roof.
    Battery maintainer has been plugged in all week.
    FEP Supporter webestang's Avatar
    St. Louis, MO.
    Going to be 58 tomorrow, need to uncover and take him for a drive.
    Scotty
    1999 Mustang Coupe V6 Auto Chrome Yellow -Rebuild Coming Soon.
    1996 Crown Vic LX 4.6 Silver "Gort" Daily Driver
    Past Pony's.....
    FEP Supporter STANGMAN116's Avatar
    Mar 2013
    DENVER CO, the 303
    Welp i had to relocate the herd for a couple weeks so today moved 6 cars then the rest tomorrow.
    got the old engine out and tore it down. Was rebuilt somewhere down the line. Crank was turned .10/.10, bored .30 over with new pistons....all that care and the rods were installed wherever the builder threw them lol totally out of order.
    Removed the eec and associated wiring and sensors, vacuum lines etc and started the cleanup of the engine bay. What a mess of snakes that was lolName:  20190204_143654.jpg
    Walked by my 82 RS about 30 times today and did absolutely NOTHING to it!
    I did start cleaning up the good used floor pan for it a bit yesterday. Nothing worthy of pictures, but did cut/drill/grind the extra firewall metal off the pinch weld at the front. I hammer and dollied the sides to straighten up all the spot welds cut out. Just need to finish cleaning everything up and then a LONG Weekend to cut out the original and weld in the new floor.
    1984 SVO Awaiting Restoration
    Apr 2010
    Portland, Oregon
    A little snow this morning.
    Well today I unwrapped the wire harness and separated the engine harness from the light harness. Got the light harness fixed up and wrapped with new plastic split loom protector and tucked away up the drivers side fender well...that was the easy part lol. Tomorrow I'll start repairing the few burned wires I found in the engine loom.
    Well, today I went to a jy to look at a 4 eye they had listed on cl for a battery tray and the washer bottle reservoir I need. I was so bummed out it was picked clean except the dirty engine with rat turds all over it. Looked a little closer and scored a performer intake for $50 woohoo.
    Jan 2007
    Quartz Hill, California
    Just finished putting on the new timing cover and polished aluminum water pump on the RS. My old cover had a few stripped out bolts and was driving me crazy with oil leaks. The water pump was just an upgrade that I figured I would do seeing as I had it all apart. All fixed now!
    Robert
    My RS in Action
    Quote Originally Posted by rich75043 View Post
    Indicative of the non-care shoddy practices of some of the conveyor belt "rebuild" industry, probably grabbing rods to use out of a bulk bin of 'em. Do it yourself, folks, or be the supervisor of it all working with a machine shop or builder. Nobody is going to take care for whatever is your engine or is to become your engine than YOU. The '89 truck 302 engine that I took apart back in the summer also has 10-under crank journals and 30-over cylinders and flat tops, and by the looks of everything, not too many miles ago... but, there was no oil hole chamfering done on the journals, 6 of 8 pretty new looking flat top pistons have small skirt cracks (maybe from a pi$$ pounding, and/or the much-loved "cold drive-ability" common since fuel injection, maybe from overheating (no other signs of that), etc...), and there were also nonsense numbered rods in it... as in some with no legible numbers, two # 7's (neither AT # 7), etc... albeit all rods installed correctly with the larger crank bore chamfers located at crankshaft journal ends. I have number stamps, and will be properly numbering them before replacement pistons go back on.
    1983 Mercury Cougar 3.8L LS
    1981 Mercury Marquis Brougham
    1971 Mustang Fastback
    1974 Pontiac Luxury LeMans
    Just received a half dozen heavy long boxes... cylinder heads!
    Default sno spoiler
    Brushed off frozen snow. Partially tarped, parked for now. Car told me (wear sensors) it needs ft brake pads.
    Melting icy snow sheet slid down the hatch glass. Good for a couple more pounds of down force from weight alone...
