Results 1 to 5 of 5
    Default canister on driver side exhaust manifold
    One more question. Their is a canister that looks like a vaccumn canister that has a connection for a line. What is it for & what connects to it. This is on the back side of drivers side exhaust. Thanks! Fran
    Pictures? Year? Engine?
    Sounds like it might be the vacuum reserve canister. That helps to keep/smooth vacuum at idle. That's because the cam/engine is "lopey" (https://www.corvetteforum.com/forums...ivability.html , https://ls1tech.com/forums/generatio...-ness-cam.html ).
    If your car is a 85 GT with the M code engine it’s the vacuum controlled heat riser valve. Used to help speed engine warm up.
    From memory, its a vacuum canister called a Heat Valve. Heat VLV
    See qikgts Vaccum Emissions Control Info diagram CHB E5AE_9C485 for his 1985 Hi Altitude 4V GT.
    Heat VLV.
    Its a normally open canister which controls the exhaust diversion to the primary light off catalyst.
    boboli photoed it, its the item on the top of the picture that looks like a waste gate actuator.
    http://vb.foureyedpride.com/showthre...1985-Emissions
    http://vb.foureyedpride.com/showthre...-exhaust/page2
    The earlier 83 and 84's with 4-bbl carbs (not the CFi's) had no tubing headers, and had another kind of secondary heat stove which blocked off one side of the exhaust to pre-heat the primary light off oxidation catalyst.
    Its some times called a flapper valve too. The 85's have a bigger 2.75" one, not the earlier 2.375".
    http://vb.foureyedpride.com/showthre...23#post1656823
    Quote Originally Posted by boboli View Post
    Since you asked about the heat riser, I found one of the 85 ones I have. I think I tossed the other long ago. There are 2 on ebay right now( 1 used and 1 new) that look exactly the same.
    from the rear
    from the engine side
    the label on the vacuum canister has long since been destroyed, so I can't read any #'s. The label almost looks to have a bluish color, but I can't say if that is original or just from time. The original on ebay has a red sticker. Maybe they are color coded to size? The only cast # on the valve body is a #4 right at the corner, near the vacuum canister.
