I found my build sheet while replacing my carpet. (Under drivers seat) Do you have any information on how to decode it? I emailed Marti, they could not help. Thanks Arnie.
I can do it but I need a larger image of the sheet.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
I sent you an email message through this site.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
VIN
1FA = Ford vehicle manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
28 = Mustang 3-door sedan (hatchback)
M = SEFI H.O. 5.0L V8 engine
5 = VIN check digit
G = 1986 model year
F = Dearborn Assembly
206029 = 106,029th 1986 Ford scheduled for production at Dearborn Assembly
Build Sheet
Line X
860214 1447 = build sheet printed on February 14, 1986 at 2:47 PM
Line A
Rotations Number - 6538 = trim & chassis rotations #6538
Line - Z = Mustang model line
VIN - P28GF202029 = [VIN decoded above]
Body Type - 61B = Mustang 3-dr hatchback
Body, Tops, Color - [blank] = no convertible top
Body, Tops, Roof - [blank] = no sunroof, no T-roof
Ext, Paint, Body - 3J = Light Regatta Blue Metallic exterior paint color
Ext, Paint, Accent - [blank] = no accent paint
Ext, Tutone - [blank] = no tu-tone paint
Int, Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior color (A)
Int, Deviation - [blank] = no interior trim deviation
I.B. Color - A = Charcoal instrument panel color
Type of Order - 1 = Retail order
Region & District - 47 = Cincinnati district sales office
Special Order - [blank] = not a special order
Line B
Emission Control - [blank] = no special emissions package
Engine - M = SEFI H.O. 5.0L V8 engine
Trans - 2 = Borg Warner 'T-5' 5-speed manual overdrive transmission
Air Cond - M = manual air conditioner
Engine, Tag Number - ZK341AA = unknown calibration (Z), Thermactor emissions with or without A/C (K), 5.0L engine (341), calibration and revision level AA
Therm, Air Pump - MO = 5.0L engine Thermactor air pump
Transmission, Part Number - E6ZRFB = manual transmission (R) originally engineered for 1986 (E6) Mustang (Z), release level FB
Seats, Type - 6 = Articulated Sport seating
Belts, Color - A = Charcoal/Grey seat belts
Carbon Canister - X = 5.0L engine carbon canister
Modules, Ign. - 5 = 49-state 5.0L/T-5 ignition module ignition module
Modules, EEC/MCU - AVM = 5.0L engine, manual transmission, unknown calibration
Air Cleaner, Part Number - E6SB = air filter housing originally engineered for 1986 (E6) Thunderbird (S)
Bypass or Diverter Valve - BK = 5.0L engine Thermactor bypass & divertor valves
Line C
Imm Block Heater - [blank] = no engine block immersion heater
Power Steering, Oil Cooler - A = power steering cooler
Power Steering, Pump - R = power steering pump for 3.8L engine and 5.0L engine with T-5
Power Steering, Hoses - 8G = power steering pump for 5.0L engine with A/C
Radiator, Part Number - 3ZJ = radiator for 5.0L engine without transmission fluid cooler
Fan, Part Number - 65A = 5.0L engine fan
Alternator, Wiring 14305 - [blank] = alternator wiring for 5.0l engine
Alternator, Code - 6S = alternator for 5.0L engine with T-5 transmission
Drive Belts, A/C - P = drive belt for 5.0L engine with A/C
Drive Belts, Power Steering - P = power steering drive belt for 5.0L engine with A/C
Drive Belts, Alternator - P = alternator drive belt for 5.0L engine with A/C
Vacuum Solenoid - F = vacuum solenoid for 5.0L engine
Line D
Groups, Décor, Appear - B = GT package
Electrical, Wipers - W = interval windshield wipers
Electrical, Defroster - E = electric rear defrost
Electrical, Audio, Radio - R = AM/FM stereo with cassette tape player
Electrical, Audio, Spkrs - Z = four speakers with premium sound system
Electrical, Lights, Light Group - V = visibility/light group
Power Aids, Deklid Release - F = remote decklid release
Power Aids, Locks - [blank] = no power door locks
Power Aids, Windows - [blank] = no power side windows
Glass, Tint - T = tinted glass
Mouldings, Rocker - [blank] = no rocker moulding
Air Dam - G = GT front bumper cover
Road Abrasion - [blank] = no road abrasion coating
Carpet/Mats - G = grey floor mats
Console - C = console
Mirror, Vanity - N = passenger side vanity mirror
Mirror, Outside - A = dual remote control mirrors
Line E
Battery - DC = heavy duty battery (54 amp-hr)
Driveline, Speed-O, Metric - [blank] = no metric speedometer
Driveline, Speed-O, Gear 2 - M = Maroon (C4OZ-17271-A) speedometer driven gear
Driveline, Driveshaft, Color Codes - PBW = driveshaft for 5.0L engine with manual transmission
Driveline, Rear Axle, Tag Number - 201A = 2.73:1 axle ratio, Traction-Lok (limited slip) differential
Suspension, Springs, Front, Left - MOL = O front left spring code
Suspension, Springs, Front, Right - MOL = O front right spring code
Suspension, Springs, Rear, Left - MID = B rear left spring code
Suspension, Springs, Rear, Right - MID = B rear right spring code
Stabilizer Bars, Front - YB = Yellow and Blue paint daubs on front stabilizer bar (5.0L bar)
Stabilizer Bars, RR - B = Blue paint daub on rear stabilizer bar (5.0L non-SSP bar)
Pkgs, Hndlng - X = Handling Suspension package
Line F
Wheel Area, Wheel Covers - Z = wheel covers w/ embossed Ford oval
Wheel Area, Wheels 1/2 - ZZ = 15" x 7" cast aluminum wheels
Tires, Goodyear - 4 = Goodyear tires
Tires, Size - 22560VR = P225/60VR15 tires
Tires, Color - [blank] = black sidewall tires
Tires, Spare - M = mini spare tire
Tires, Quantity - 4 = four full size tires
Speed Control - [blank] = no cruise control
Front End, Cover/Pad - Z = vinyl wrapped GT steering wheel with Ford oval
Front End, Steering Wheel, Type Wheel - 2 = steering wheel without cruise
Front End, Steering Wheel, Type of Col - T = tilt steering wheel
Clusters - 6A = instrument cluster with 7K tachometer and 85 mph speedometer
Hood Scoop - [blank] = no hood scoop
Frt License Plate Bracket - X = front license plate bracket
Line G
Accent Stripe, Type/Color - G2 = Dark Charcoal hood stripe, Dark Charcoal GT hood decal and "Mustang GT" hatch/trunk decal
Export/French - [blank] = no French labels
VIN - 1FABM5 = [VIN decoded above]
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Thank you Decoder Guy for getting back to me so fast, now that I found the build sheet I have all the paperwork for my Mustang.
What other items do you have that you will share? I collect, database, and decode them all. Door tag, buck tag, owner card, window sticker, engine calibration label, carb tag, distributor tag, transmission tag, axle tag, ...
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
