Results 1 to 7 of 7
    Default Build Sheet Decoding
    I found my build sheet while replacing my carpet. (Under drivers seat) Do you have any information on how to decode it? I emailed Marti, they could not help. Thanks Arnie.
    I can do it but I need a larger image of the sheet.
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Can I send you a copy, or how can I send you a larger copy?
    I sent you an email message through this site.
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    VIN
    B = active belts, no airbags
    P = passenger car
    28 = Mustang 3-door sedan (hatchback)
    M = SEFI H.O. 5.0L V8 engine
    5 = VIN check digit
    G = 1986 model year
    F = Dearborn Assembly
    206029 = 106,029th 1986 Ford scheduled for production at Dearborn Assembly
    Build Sheet
    Line X
    860214 1447 = build sheet printed on February 14, 1986 at 2:47 PM
    Line A
    Rotations Number - 6538 = trim & chassis rotations #6538
    Line - Z = Mustang model line
    VIN - P28GF202029 = [VIN decoded above]
    Body Type - 61B = Mustang 3-dr hatchback
    Body, Tops, Color - [blank] = no convertible top
    Body, Tops, Roof - [blank] = no sunroof, no T-roof
    Ext, Paint, Body - 3J = Light Regatta Blue Metallic exterior paint color
    Ext, Paint, Accent - [blank] = no accent paint
    Ext, Tutone - [blank] = no tu-tone paint
    Int, Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior color (A)
    Int, Deviation - [blank] = no interior trim deviation
    I.B. Color - A = Charcoal instrument panel color
    Type of Order - 1 = Retail order
    Region & District - 47 = Cincinnati district sales office
    Line B
    Emission Control - [blank] = no special emissions package
    Engine - M = SEFI H.O. 5.0L V8 engine
    Trans - 2 = Borg Warner 'T-5' 5-speed manual overdrive transmission
    Air Cond - M = manual air conditioner
    Engine, Tag Number - ZK341AA = unknown calibration (Z), Thermactor emissions with or without A/C (K), 5.0L engine (341), calibration and revision level AA
    Therm, Air Pump - MO = 5.0L engine Thermactor air pump
    Transmission, Part Number - E6ZRFB = manual transmission (R) originally engineered for 1986 (E6) Mustang (Z), release level FB
    Seats, Type - 6 = Articulated Sport seating
    Belts, Color - A = Charcoal/Grey seat belts
    Carbon Canister - X = 5.0L engine carbon canister
    Modules, Ign. - 5 = 49-state 5.0L/T-5 ignition module ignition module
    Modules, EEC/MCU - AVM = 5.0L engine, manual transmission, unknown calibration
    Air Cleaner, Part Number - E6SB = air filter housing originally engineered for 1986 (E6) Thunderbird (S)
    Bypass or Diverter Valve - BK = 5.0L engine Thermactor bypass & divertor valves
    Line C
    Imm Block Heater - [blank] = no engine block immersion heater
    Power Steering, Oil Cooler - A = power steering cooler
    Power Steering, Pump - R = power steering pump for 3.8L engine and 5.0L engine with T-5
    Power Steering, Hoses - 8G = power steering pump for 5.0L engine with A/C
    Radiator, Part Number - 3ZJ = radiator for 5.0L engine without transmission fluid cooler
    Fan, Part Number - 65A = 5.0L engine fan
    Alternator, Wiring 14305 - [blank] = alternator wiring for 5.0l engine
    Alternator, Code - 6S = alternator for 5.0L engine with T-5 transmission
    Drive Belts, A/C - P = drive belt for 5.0L engine with A/C
    Drive Belts, Power Steering - P = power steering drive belt for 5.0L engine with A/C
    Drive Belts, Alternator - P = alternator drive belt for 5.0L engine with A/C
    Vacuum Solenoid - F = vacuum solenoid for 5.0L engine
    Line D
    Groups, Décor, Appear - B = GT package
    Electrical, Wipers - W = interval windshield wipers
    Electrical, Defroster - E = electric rear defrost
    Electrical, Audio, Radio - R = AM/FM stereo with cassette tape player
    Electrical, Audio, Spkrs - Z = four speakers with premium sound system
    Electrical, Lights, Light Group - V = visibility/light group
    Power Aids, Deklid Release - F = remote decklid release
    Power Aids, Windows - [blank] = no power side windows
    Mouldings, Rocker - [blank] = no rocker moulding
    Air Dam - G = GT front bumper cover
    Carpet/Mats - G = grey floor mats
    Console - C = console
    Mirror, Vanity - N = passenger side vanity mirror
    Mirror, Outside - A = dual remote control mirrors
    Line E
    Battery - DC = heavy duty battery (54 amp-hr)
    Driveline, Speed-O, Metric - [blank] = no metric speedometer
    Driveline, Speed-O, Gear 2 - M = Maroon (C4OZ-17271-A) speedometer driven gear
    Driveline, Driveshaft, Color Codes - PBW = driveshaft for 5.0L engine with manual transmission
    Driveline, Rear Axle, Tag Number - 201A = 2.73:1 axle ratio, Traction-Lok (limited slip) differential
    Suspension, Springs, Front, Left - MOL = O front left spring code
    Suspension, Springs, Front, Right - MOL = O front right spring code
    Suspension, Springs, Rear, Left - MID = B rear left spring code
    Suspension, Springs, Rear, Right - MID = B rear right spring code
    Stabilizer Bars, Front - YB = Yellow and Blue paint daubs on front stabilizer bar (5.0L bar)
    Stabilizer Bars, RR - B = Blue paint daub on rear stabilizer bar (5.0L non-SSP bar)
    Pkgs, Hndlng - X = Handling Suspension package
    Line F
    Wheel Area, Wheel Covers - Z = wheel covers w/ embossed Ford oval
    Wheel Area, Wheels 1/2 - ZZ = 15" x 7" cast aluminum wheels
    Tires, Goodyear - 4 = Goodyear tires
    Tires, Size - 22560VR = P225/60VR15 tires
    Tires, Color - [blank] = black sidewall tires
    Tires, Spare - M = mini spare tire
    Tires, Quantity - 4 = four full size tires
    Speed Control - [blank] = no cruise control
    Front End, Cover/Pad - Z = vinyl wrapped GT steering wheel with Ford oval
    Front End, Steering Wheel, Type Wheel - 2 = steering wheel without cruise
    Front End, Steering Wheel, Type of Col - T = tilt steering wheel
    Clusters - 6A = instrument cluster with 7K tachometer and 85 mph speedometer
    Hood Scoop - [blank] = no hood scoop
    Frt License Plate Bracket - X = front license plate bracket
    Line G
    Accent Stripe, Type/Color - G2 = Dark Charcoal hood stripe, Dark Charcoal GT hood decal and "Mustang GT" hatch/trunk decal
    Export/French - [blank] = no French labels
    VIN - 1FABM5 = [VIN decoded above]
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Thank you Decoder Guy for getting back to me so fast, now that I found the build sheet I have all the paperwork for my Mustang.
    What other items do you have that you will share? I collect, database, and decode them all. Door tag, buck tag, owner card, window sticker, engine calibration label, carb tag, distributor tag, transmission tag, axle tag, ...
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
