Results 1 to 8 of 8
    Feb 2009
    Jackson, NJ 08527
    Default Coyote looking, forward opening intake......................
    Guy on the Classicbroncos MB is designing and maybe building a Coyote "looking", front TB opening intake
    that connects to GT-40/explr lower. Thought some of you might like to see it. Neat idea if it
    gets off the ground.
    I logged out of that board and can still open the pics one by one.
    (they just don't show up in the thread, as they would if you had an account on that MB).
    http://classicbroncos.com/forums/sho...d.php?t=292591
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Not working like that from here. Says I must log in blah blah... Cool idea though. Would love to see it but I'm not up to registering now. Maybe another time.
    '85 GT
    Feb 2009
    Jackson, NJ 08527
    Got permission to post pics.
    Wow! That is cool!
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Killer rendering! Thanks for posting up the pix!
    Lots of plenum area. Maybe too much? IDK the answer just an observation.
    '85 GT
    Dec 2009
    St. louis MO
    Might be a good intake for a turbo setup
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Feb 2012
    Mississauga Ontario, Canada
    That design looks amazing!!
    Oct 2010
    Lebanon, IL
    They might want to look in to the way Yamaha did it for the SHO engine. Bet there is something to the connecting tube at the back (front?) of the manifold. Intakes that have isolated banks (plenums) usually have dual throttle bodies.
    The Coyote cover makes the engine look like that but it has a common plenum.
    BBD PERFORMANCE
    HIGH PERFORMANCE PARTS
    CUSTOM ENGINE BUILDS
    CUSTOM CAM DESIGNS
    1983 CRIMSON CAT OWNER
