Results 1 to 9 of 9
    Default Fairmont/LTD aluminum driveshaft - 5.0 T5 8.8 - Explorer??
    So I have a 86 LTD Wagon with a 5.0, T5, and 8.8 rear. Currently have a turbocoupe driveshaft. I’ve read that the 95-00 4dr 4.0 2wd Explorer aluminum driveshaft will bolt up after changing the yoke and flange with my existing stuff. I haven’t found where many people have actually confirmed this conversion works. Any feedback out there guys???
    Apr 2010
    Portland, Oregon
    Check my build thread in the signature line.
    I believe that the Aerostar van was supposed to be a source of an aluminum DS that would bolt in. I never found on in a junkyard that wasn't bent to try it though.
    Jess
    Sorry didn't notice that this wasn't for mustangs. Disregard.
    Previously owned;
    Apr 2010
    Portland, Oregon
    My 2.3T/T-5 Pinto used an Aerostar AWD aluminum rear drive shaft.
    It does work. I used one for many years. I'd still have it if I hadn't moved my engine back.
    Thanks for the feedback. Would you say it was worth the swap? How was the yoke engagement?
    Quote Originally Posted by Bsdoig View Post
    Yoke engagement was a bit outside ideal, but with my aftermarket k-member, my engine was sitting unusually far forward.
    This seems like the best option. Need to check my exhaust clearence. If that isn’t an issue, I may give this a try to see if it gets rid of my small driveline vibs.
    It certainly did mine. My steel driveshaft was dented and I have 4.10 gears.
