Results 1 to 8 of 8
    Default 1984 GT Stalling, Shutting Off
    Ok guys, just when I though I had something fixed it comes back with a vengeance. I have a 5.0 AOD 84 GT. I have replaced the following:
    Spark Plugs, Wires, Engine Coolant temp sensor, MAF sensor, Ign coil, distributor cap and rotor, EGR Valve, and fuel filter. What I am chasing is the car intermittently shuts off, stalls when I am at stopped. Engine is warmed up. I have to put in neutral and hit the gas to keep it running. Sounds like it misses sometimes when foot is on gas pedal trying to keep it running. But while I am at speed it doesn't. I changed plugs and wires hoping that was gonna fix it. It did not. Not sure where to go from here. Any suggestions? This fuel injection motor is a lot more complicated than the carb motor 5.0 I previously owned. Any help would be appreciated.
    That would be map sensor right? I would try the Pip next if I were you. Super easy but you do need to pull the gear off the distributor to do it. Can you tell us the error codes? Pip would throw an error.
    Yes, my typo it was a MAP sensor. What is a PIP? I will check code.
    Pip is the sensor inside the distributor. Simple but tough placement.
    Reman / new distributor is much easier generally. Make sure the seals in the distributor are ok while you are checking stuff. Oil residue will cause a pip / ignition stator (whatever term you prefer) malfunction.
    Be super careful looking for a reman if you go that way, I tried 5 different distributors from different manufacturers, even a 400 dollar top end job, and none of them were correct for the car. The problem is the TFI in 1984 has a roughly 8mm shorter shaft than the later models and didn't exist on earlier cars. Eventually I was forced to just reuse mine after replacing the pip. Even getting a new gear was difficult since they don't make a cast gear with that inner diameter any more.
    but do check your codes before you do anything, pip would show up if that is the problem. TFI could also be flaky but that should show a code too.
    That’s a good point. Forgot that there is a length difference
    -- James
    My four eyed foxes:
    past foxes -
    Grand Rapids, MI
    Seems like it might be more of an air/fuel than spark thing, but I would definitely check for codes as mentioned. When the PIP and/or ignition module in my car crapped out it would just stall once it got warm enough as you were driving down the road. It also wouldn't restart until everything cooled down sufficiently (15-20 minutes). I know you say it is intermittent, but I would also check for vacuum leaks or just replace any vacuum hoses you can find (might just be easier), if you have any doubts about the integrity of the hoses.
    This guy had a similar issue albeit with a different ignition system. Might be some nuggets of information in there for you although it doesn't look like he really every notes what (if anything) fixed it.
    http://vb.foureyedpride.com/showthre...great-at-speed
    This might have some good info for you to dig through as well:
    http://vb.foureyedpride.com/showthre...n-84-CFI-setup
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
