Results 1 to 10 of 10
Thread: K member brace?
    Feb 2012
    Mississauga Ontario, Canada
    Default K member brace?
    Hi guys. Is their a four point k member brace that will clear bbk long tube headers? I have a 1985 T-Top car. I would like to brace the front a bit better.
    FEP Power Member smitty54's Avatar
    Oct 2012
    North Attleboro, Ma
    This is the one that I have from Maximum Motorsports. You'd have to check your height and their specs to see it would fit.
    https://lmr.com/item/MM-MMKB41/1979-...oupe-Hatchback
    "Have you ever noticed that anybody driving slower than you is an idiot, and anyone driving faster than you is a maniac."
    George Carlin, Rest in peace
    Rick
    84 GT Convertible
    68 Cougar XR7
    14 Ford Explorer Limited
    Feb 2012
    Thanks for the link. I checked the notes on the site. It states that it won't work with long tube headers.
    I think if you want long tubes AND the lower chassis rigidity that this piece offers you need to get an aftermarket k-member which comes with a 2 point brace (MM version) that does clear long tubes.
    05 Corvette Z51
    Old school works well..... here is what Saleen bolted into the 84-86 (or 87?) cars
    Buy some 3/4”x3/4” square tube
    cut it to length so it fits (as pictured)
    cut the ends (as pictures) so you have room to install a bolt.
    Saleen used Allen head bolts with nuts on the top of the K member
    Easy-Peezy
    \____/
    Feb 2012
    Thanks for the info. I never knew Saleen put a brace back in the 80's.
    Yes. And the single bar fits well and does 95% of what the newer designs do.
    Feb 2012
    Thanks for the great advice How much of an improvement did you notice, once you installed it?
    My 88xr7 has a two point from the factory. Wouldn't know unless you looked. Doesn't feel any different then my two 86's.
    Quote Originally Posted by 86MustangGtRob View Post
    Its a build .... bought the Racecraft suspension 85GT as a roller. But they were clearly added with good reason. Otherwise there wouldn’t be any such braces.
    Best results will come with a spherical bearing in a caster camber plate rather than onion head stock style strut upper plate.
    Also a strut tower brace.
