    Default Hatch trim panel
    I've searched but didn't find any results, so here's my question. Does anybody know if a trim panel is available for the inside of the hatch?
    I found one for my 03 Cobra that an aftermarket company makes and it's a nice piece so I'm looking for one for the 86. I have seen them on some later models but don't know if they were factory or aftermarket.
    Throughout the years Ford offered some different options for the area of the hatch below the rear glass. Some were a fiber board product that generally didn't hold up well. There was the plastic cover with the bulge that was originally for the rear wiper option and later used on the 84-86 SVO models. Then in 1987 Ford started using the flat plastic cover/trim panel at least on the loaded models.
    You can make any of them work. Worse case you will need to drill some holes that match up to the door panel style clips that hold the plastic panels in place. Good Luck1
    https://www.ebay.com/itm/87-93-Ford-...-/183266605238
    Be VERY careful when drilling the holes to mount these! When the drill bit breaks through the sheet metal the drill can VERY EASILY shove through and punch the top layer of the hatch and put an upside down ding in it that is incredibly visible from the outside. I haven't actually done it, but I was there in person when it was done. Major damage caused. Nobody noticed until the hatch was lowered and then everyone went.............OHH @#$%. The 87-93 one is the one you probably want. Plenty around in many colors and it fits and looks nice. EDIT: And also make sure your sheet metal screws are short enough that the plastic cover tightens before the screw makes a similar upside down ding.
    May 2003
    Roseburg Oregon
    I believe the 87 up hatch cover is held with screws about 1 and a half inches long , and self tapping .
    As always you guys are the shizzle, thanks. As far as the drilling goes I always am aware of the dangers of doing this, that's why I always put a small vacuum hose on the drill so it doesn't cause a calamity when drilling like mentioned.
