Results 1 to 3 of 3
Thread: spring codes
    Oct 2004
    Moyock, NC - (Hampton Roads)
    Default spring codes
    As usual - i can spend hours looking at all the useful info on this site - and have.
    I am curious to the front and rear spring codes mean. Not sure i understand what the differences are. do the codes relate to different part numbers ? If they do - i bet if you ordered springs for an 86 gt - there would be one part #... ?? or does this have nothing to do with actual part numbers ?
    on my 86 GT, my spring codes (beside the TRAN Code on the door tag) are OOBB (front/rear).
    I have pulled up other door tags listed here that are pretty much the same cars (85/86) and some springs are different. I have seen TT,SS, etc.
    any reason why a lot of these codes are different from what appears to me to be mostly / same configuration ?
    thanks,
    jason
    I'll get a list later of all the codes we have come across that I have in my database.
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    GT
    convertible/5.0L/AOD = BBTT, PPCC, PPTT
    convertible/5.0L/T-5 = BBTT
    hatchback/5.0L/AOD = BBTT, OOTT
    hatchback/5.0L/T-5 = AABB, OOBB, OOTT
    LX
    coupe/5.0L/AOD = BBSS, OOSS
    coupe/5.0L/T-5 = AASS
    convertible/5.0L/AOD = PPCC
    convertible/5.0L/T-5 = ?
    hatchback/5.0L/AOD = BBBB
    hatchback/5.0L/T-5 = OOBB
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
