Results 1 to 4 of 4
    Default Advice on 2.3 build
    I bought a 1988 merkur xr4ti just for the 2.3 turbo in it im swapping it into a 1989 mustang lx I want to make 400-500hp for my build i need advice on what injectors I should get and if the stock merkur computer can run them (80lb+ injectors) and also what camshaft to get?? any ideas because all injectors I find seem to need a performance computer that i dont have the money for so if i need a computer whats would be a budget computer that would run 80lb+ injectors
    Apr 2009
    Acworth, GA
    There is a lot of useful information here and on Turboford.net about proven combinations.
    Quick answers
    - no your stock computer won't work at that level.
    - look at the microsquirt Stinger-performance.com sells (not just the Pimpx versions, scroll past the Pimpx section)
    - in addition to injectors you'll need to dump the vam so the pimpx or microsquirt are your best bets.
    Jan 2004
    Arlington Washington
    As for camshaft get ahold of boport he's back up and running.
    1982 Capri RS 5.0L
    1985 SVO 2A & leather.
    Just wondering are you planning on building 4-500 wheel HP or crank HP?
