Results 1 to 19 of 19
    Default Front fender extension ?
    Are the front fender extensions on the 85 mustang the same as the 91-93 lx?
    Stephen Johnson
    SS/D 427 Ford Fairlane NHRA-IHRA
    National Record Holder 9.49 @ 139mph
    1985 Mustang daily driver
    10.88mph 125mph N/A 337
    Apr 2009
    Denver, Colorado
    Nope....
    Current rides:
    89 LX 5.0, 5 -spd..the Lemon
    86 RS Capri 5.0 Auto...
    85.5 SVO, Finally Got Boost
    The fender extension you need were used on the mid year 84 GT with Fog Lamps and the 85/86 All Model Mustangs.
    The 87-90 front extensions are unique to those models as well as the 91-93 front extensions.
    You should consider posting a WTB in the Classified section. Good Luck!
    Just great.... I've been searching every where I can think of.... Any idea of any companies that sell them?
    Stephen Johnson
    To my knowledge they are not reproduced at this time.
    I have a couple myself, just not sure I want to let them go just yet. I would recommend posting a WTB in the Classified section and see if any FEP members have some spares. You can also check Ebay, Craigslist, etc. They are out there, just need to know what you are looking for. I know there was an E4ZZ and an E5ZZ part number, not sure about any E6ZZ. Bottom line if the part number doesn't start out E4, E5, or E6 then you know they are not the ones you need. Good Luck!
    Jul 2004
    Montebello, CA
    Johns cougars makes them with great quality, I bought 2 for my 86 and they were great! at $85.00 each but had them in a week
    Past 4 eyes-
    U.S. NAVY 1980-2009
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    For a Mustang? Looks like only a Capri or early Mustang. He's needing for an '85 Mustang.
    https://www.johnsclassiccougars.com/...Code=MCR%2D100
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue-sold
    '93 COBRA Teal Metallic-sold
    '86SVO Oxford White-sold
    '86GT 'Vert True Blue-sold
    '81'GT' Medium Red-sold
    Quote Originally Posted by escogt View Post
    you are correct... I need for 85 mustang not a capri
    Stephen Johnson
    Jan 2006
    Long Island, N.Y.
    Quote Originally Posted by 1Quik85GT View Post
    Good luck!!!
    As mentioned the John's Cougars fender extensions are for the 79-82 Mustangs using the Pace Car/Cobra/GT front lower air dam. They also fit the 84-86 Capri RS with the OEM front air dam. Obviously they can fit any other Mustang or Capri that has been retrofitted with the lower air dam also.
    They are NOT correct for the 84.5 Mustang GT with fog lamps or the 85/86 Mustangs with the OEM front bumper cover. Good Luck!
    Not having any luck... The ones I find are either cracked or missing studs
    Stephen Johnson
    If the extensions are cracked, they are just fiberglass and can be repaired using standard body work and fiberglass repair.
    If the mounts for the studs are intact, but just the stud missing then you can order these as replacements. They work for the hood scoops, the fender extensions, and the headlamp/front bumper support. https://lmr.com/item/LRS-16630HDW/mu...dware-kit-7982
    If the mounts for the studs are stripped out, then you want to use either some fiberglass resin or fiberglass infused filler for the repair. Pack the mount about 1/2 full of the resin/filler and then carefully thread in the new studs.
    I generally use a 2 part urethane adhesive for my stud repairs. Some like epoxy also. Whatever works for you. Good Luck!
    Jul 2004
    Montebello, CA
    are these what your looking for? I've had these 3 sets for saleName:  thumbnail (1).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
    what's the part numbers on them?
    Stephen Johnson
    Please NO Buying or Selling outside of the Classified sections.
    Either work this out via PM or in the Classified section. Thank you for your attention in this matter.
    Jul 2004
    Montebello, CA
    Yes P.M me
    Past 4 eyes-
    U.S. NAVY 1980-2009
    Thanks pm sent
    Stephen Johnson
    did you find what you need? i PMed also.
    Found some thanks guys
    Stephen Johnson
