Results 1 to 3 of 3
    Default Molding Stripe Source?
    I have an 82 with the yellowish gold molding stripes. Anyone found a source that accurately reproduces them?
    Your best option is probably going to be checking with your local auto body/paint supplier and see what if they have a 3M pinstripe catalog or similar. You should be able to find a similar color and then order in the correct size you need. 1/8" is usually the correct size for the body side moldings.
    If that doesn't work, then you might also check with any local vinyl graphics local to you as they can do similar things. Good Luck!
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Jon,
    Trey has a great Idea with a vinyl supplier. For whatever reason I am thinking you will have a hard time finding the colour you need out of 3M or similar.
    Let us know what you find.
