VIN
1FA = Ford vehicle manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
28 = Mustang 3-door sedan (hatchback)
M = H.O. 5.0L V8 engine
9 = VIN check digit
E = 1984 model year
F = Dearborn Assembly
175834 = 75,834th 1984 Ford scheduled for production at Dearborn Assembly
Buck Tag
MUSTANG = Mustang model line
61B = Mustang 3-dr sedan (hatchback)
____ = body & paint rotations #____
9LL = Oxford White exterior paint color
DF
ST
AC = manual air conditioner
04 = YES rear defrost, YES rear wing
HB = heated backlite (rear defrost)
S = speed control (cruise control)
ANN = G.T.350 model/trim level
WD = power side windows (W), power door locks (D)
01 = no hood scoop
ELECTRIC
-D = Canyon Red interior trim color
CI = central injection (CFI)
NLR(?)
4(?)
Build Sheet
Line A
Rotations Number - 0481 = trim & chassis rotations #0481
Line - Z = Mustang model line
VIN - P28EF175834 = [VIN decoded above]
Body Type - 61B = Mustang 3-dr sedan (hatchback)
Body, Tops, Color - [blank] = no convertible top
Body, Tops, Roof - [blank] = no sunroof, no T-roof
Ext, Paint, Body - 9L = Oxford White exterior paint color
Ext, Paint, Accent - [blank] = no exterior accent paint
Ext, Tutone - [blank] = no tu-tone paint
Int, Trim - PD = cloth Articulated Sport seating (P), Canyon Red interior trim color (D)
Int, Deviation - [blank] = no interior trim deviation
I.B. Color - D = Canyon Red instrument panel color
Type of Order - 7 = Local Promotion order
Region & District - 42 = Cleveland district sales office
Special Order - [blank] = not a special order
Line B
Emission Control - [blank] = no special emissions package
Engine - M = H.O. 5.0L V8 engine
Trans - T = automatic overdrive (AOD) transmission
Air Cond - M = manual air conditioner
Engine, Tag Number - EK334AB = 49-state calibration (E), Thermactor emissions with or without A/C (K), 5.0L engine (334), release level AB
Therm, Air Pump - MO = Thermactor air pump for 5.0L engine
Transmission, Part Number - E4ZPAD = automatic transmission (P) originally engineered for 1984 (E4) Mustang (Z), release level AD
Seats, Type - V = Articulated Sport seating
Belts, Color - D = Canyon Red seat belts
Carbon Canister - T = carbon canister for 5.0L engine with automatic transmission
Modules, Ign - [blank] = TFI ignition module
Modules, EEC/MCU - CK = electronic engine control (EEC) module calibration code for 5.0L/AOD
Air Cleaner, Prefix - E4 = air filter housing original engineering for 1984
Bypass or Divertor Valve - JB = Thermactor bypass and divertor valves for 5.0L engine without California Emission System
Line C
Imm Block Heater - [blank] = no engine block immersion heater
Power Steering, Oil Cooler - A = power steering cooler
Power Steering, Pump - B = power steering pump for 5.0L engine
Power Steering, Hoses - 8G = power steering hoses for 5.0L engine
Pulley, Water Pump - 1A = water pump pulley for 5.0L engine
Pulley, Crankshaft - 4 = crankshaft pulley for 5.0L engine
Pulley, Air Pump - ZA = air pump pulley for 5.0L engine
Alternator, Wiring 14305 - 3D = alternator wiring for 5.0L engine
Alternator, Code - 66 = alternator code for 5.0L engine with automatic transmission
Drive Belts - UUUU = drive belt for 5.0L engine with air conditioner
Line D
Groups, Promot - A = G.T.350 package
Groups, Décor, Appear - B = GT
Electrical, Wipers - W = interval windshield wipers
Electrical, Defroster - E = electric rear window defroster
Electrical, Audio, Radio - R = AM/FM stereo cassette radio
Electrical, Audio, Spkrs - Z = four speakers with premium sound system
Electrical, Lights, Light Group - V = visibility/light group
Power Aids, Decklid Release - F = remote decklid release
Power Aids, Locks - P = power locks
Power Aids, Windows - S = power side windows
Glass, Tint - T = tinted glass
Mouldings, Rocker - [blank] = no rocker panel moulding
Mouldings, Bodyside, Type/Color - D = White bodyside molding with Canyon Red inset stripes and Canyon Red strip molding between wheels (G.T.350)
Air Dam - G = GT front bumper cover with foglamps
Road Abrasion - [blank] = no road abrasion coating
Carpet/Mats - [blank] = no floor mats
Console - C = console
Mirror, Vanity - [blank] = no passenger side vanity mirror
Mirror, Outside - A = dual remote-control mirrors
Line E
Battery - __ = unknown battery
Driveline, Speed-O, Metric - [blank] = no metric speedometer
Driveline, Speed-O, Gear 2 - T = tan (C7VY-17271-A) speedometer driven gear
Driveline, Driveshaft, Color Codes - PBB = driveshaft color codes for 5.0L engine with automatic transmission
Driveline, Rear Axle, Tag Number - 276E = 3.27:1 axle ratio, Traction-Lok (limited slip) differential
Suspension, Springs, Front, Left - LEA = "6" front left spring code
Suspension, Springs, Front, Right - LEA = "6" front right spring code
Suspension, Springs, Rear, Left - GAC = "X" rear left spring code
Suspension, Springs, Rear, Right - GAC = "X" rear right spring code
Stabilizer Bars, Front - YB = Yellow and Blue paint daubs on front stabilizer bar
Stabilizer Bars, RR - P = Pink paint daub on rear stabilizer bar
Pkgs, Hndlng - X = Handling Suspension package
Sus Arm Lower RR - F = rear lower control arms for 5.0L engine
Line F
Wheel Area, Wheel Covers - K = TRX wheel center caps
Wheel Area, Wheels 1/2 - XX = forged aluminum TRX wheels
Tires - 6 = Michelin tires
Tires, Spare Wheel - A = spare wheel for L, LX, GT, Turbo GT
Tires, Size - 2205VR = P220/55VR390 tires (Michelin TRX)
Tires, Color - [blank] = black sidewalls
Tires, Spare - M = temporary (mini) spare tire
Tires, Quantity - 4 = four full size tires
Speed Control - S = fingertip speed control (cruise control)
Front End, Cover/Pad & Type Wheel - B1 = Ford vinyl molded steering wheel with cruise
Front End, Steering Wheel, Type of Col - T = tilt steering wheel
Clusters - EG = LX 5.0L and GT cluster (7K tach, 85 mph speedo)
Hood Scoop - [blank] = no hood scoop
Frt License Plate Bracket - X = front license plate bracket
Line G
Heat Shield - W = exhaust heat shield for LX 5.0L and GT
Muffler - 4Z9E = muffler for LX 5.0L and GT with automatic transmission
Catalytic Converter, Left, Lite-Off - [blank] = no left, lite-off, catalytic converter
Catalytic Converter, Right, Main - HOE = right, main, catalytic converter for LX 5.0L and GT with automatic transmission
Inlet Pipes - 4D6A = inlet pipes for LX 5.0L and GT with automatic transmission
Accent Stripe, Type/Color - GD = (5.0L) G.T.350 stripes
Fuel, Sender - 6 = EFI fuel tank sending unit
Fuel, No Lead - N = "Unleaded Fuel Only" sticker in English
Fuel, Gas Qty - [blank] = 0 gallons of gas
Export/French - [blank] = no French labels
VIN - 1FABM9 = [VIN decoded above]
Owner Card
15C = March 15th scheduled build
ET 8 = 3.27:1 rear axle ratio w/ Traction-Lok differential (E), Ford 'AOD' automatic overdrive transmission (T), AM/FM stereo radio w/ auto-reverse cassette (8)
