Results 1 to 3 of 3
    FEP Member 83GLCoupe's Avatar
    Jul 2005
    Syracuse, New York 13211
    Default 1983 Mustang GL Coupe
    1983 Ford Mustang GL Coupe
    Factory V8 5.0L 4-speed car
    Boston DSO (I have the Marti report)
    9D Polar White with Medium Red Interior
    Factory AC
    Rear Defog
    True Mileage is unknown
    The car is currently disassembled because I was returning it to stock. It had been a street/strip car.
    Engine
    Motor is a later 5.0L roller with stock bottom end, E7 heads (with new valves and valve seals), factory 1983 4bbl aluminum intake,
    new water pump, new oil pump, new timing gear/chain set, new fuel pump eccentric, and new timing cover.
    New stock replacement radiator (still in box)
    New Luk 10.5" Flywheel (still in box)
    New Valeo King Cobra Clutch kit (still in box)
    New clutch cable (stock quadrant)
    BBK Unequal length headers
    Offroad generic 2.5" H pipe
    2.5" 2 chamber Flowmaster mufflers
    Polished Flowmaster 2.5" Tail Pipes
    Suspension
    4 lug restored factory 10 holes with good Mastercraft tires
    Eibach Lowering Springs
    Rear has been updated to an 8.8 Trac-lok with 3:55 gears
    Lakewood traction bars
    Factory Five rear lower control arms
    New Fuel tank with new LMR Sender (Single pickup tube no return line)
    The spare tire well has had a section removed for a sumped cell.
    I've been working on restoring the interior. I've replaced the carpet with a nice used piece. I've repainted the plastics/trim
    pieces, and replaced the broken dash hull with one from a parts car. I kept the factory radio and Premium sound from the parts car.
    The headliner material is not there, but the backing board is still in place.
    Factory gauges have been replaced with Autometer Phantom white faced units (except factory tach). I have an external white faced
    5" tach (not currently installed) to with it.
    I've completely gone through the heater box (thanks to mice) with new foam on the blend door, replaced evaporator and heater core.
    The car is tied with through the floor subframe connectors installed by PO. Floors are solid and I coated them in POR15 to keep them
    that way. Car has good shock towers and frame rails. Driver's side fender has light damage from a broken door hinge. I have 2 left
    side fenders that will go with the car (red one is from an '83, and the primed one is from a 79).
    Also with this car will go several boxes of parts that I took from the parts car and several parts that wouldn't fit in a box (i.e.
    dual snorkel air cleaner with fender tubes, extra console, front and rear wiring harnesses, etc).
    Some parts are spares since the car was mostly complete.
    Box 1
    Fan
    Fan shroud
    Battery tray and clamp
    Overflow reservoir
    Headlights
    Door mirrors
    Vacuum tree
    Headlight rings
    Horn
    Power steering bracket
    Water pump pulley
    Front side marker lamps
    Hood hinges
    Rear brake hardware
    Factory tire iron with lock
    E brake handle
    Box 2
    AC compressor
    Wiper motor
    Wiper motor transmission
    Hood latch
    Steering shaft
    AC Dryer
    Starter solenoid
    Clutch fork cover
    Hood prop
    Gas door
    Wiper arms
    Convertible trunk hinges
    AC condenser mounts
    Box 3
    Taillights
    Trunk weatherstrip
    Instrument cluster
    Armrests
    Wiper switch
    Turn signal switch
    Wiper delay module
    Bags of screws and bolts
    Information center modules
    Column cover
    Car is located in Syracuse, NY
    I'm asking $3000 or reasonable offer for the whole package. I don't want to separate parts so please don't ask. Thank you.
    The photos of the car complete are older but nothing has changed. The interior shots are of what it looks like right now. I may get to putting the seats back in over the next week or so. Name:  IMG_7375.jpg
Size:  157.3 KBName:  IMG_7332.jpg
Size:  125.6 KBName:  IMG_4713.JPG
Size:  115.6 KBName:  IMG_4142.JPG
    -1983 Mustang GL Coupe 9D Polar White (Sold)
    -1992 Mustang LX 5.0 PM Bright Calypso Green
    -2019 Jetta SEL (DD)
    -1982 Oldsmobile Cutlass Brougham (Wife's Toy)
    -2012 Nissan Xterra
    Jul 2005
    Car has been sold.
    -2012 Nissan Xterra
