Results 1 to 11 of 11
    Feb 2018
    Saskatchewan, Canada
    Default 91 302 coverted to carb update(pics)
    Some of you might remember me asking for advice on removing and converting a 91 302 efi to carb a while back.
    http://vb.foureyedpride.com/showthre...0-Removing-EFI
    Anyways, just thought I would share some pics of the progress I've made. Not as nice as some of the experts but Not bad for my first time ever messing with a engine. Thanks for the info from people that replied and helped in my previous thread.
    Before:
    Attachment 125479
    Attachment 125480
    After scrubbing and cleaning for what seems like ever lol
    Attachment 125481
    Painting
    Attachment 125482
    Attachment 125483
    Mustangs
    84.5 Gt T-top
    85 Gt
    Feb 2018
    Headers added
    Attachment 125484
    Valve covers added
    Attachment 125485
    With air cleaner on top. Still missing carb as it's getting rebuilt
    Attachment 125486
    Attachment 125487
    Attachment 125488
    Thanks for looking and opinions welcome as are suggestions on what to add next.
    Edit: apologies for the sideways last couple of pics. Not sure why they are like that.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Looking good! I would remove the smog pipe from the back of the heads and plug the holes. You can use short bolts or some use spark plugs with the ceramic broken off.
    Matt
    Looks good to me!
    Feb 2018
    Quote Originally Posted by 5.0 bird View Post
    Thanks I will do that!
    Mustangs
    84.5 Gt T-top
    85 Gt
    Looks awesome man nice work
    Looking good so far
    Feb 2018
    I removed the smog pipe and it does not look like the holes are threaded. They are very clogged with carbon. Any idea what thread type the holes are and best way to clean them up?
    Mustangs
    84.5 Gt T-top
    85 Gt
    Nice! Would look better with EFI though.
    Feb 2018
    Lol, I'd have to disagree.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Yep looking real good !!
    I believe the holes for the thermactor ports at the back of the heads are 5/8 NC threads but they will be plugged with carbon typically. I used a tap to clean mine out and then just got a short 5/8 bolt to plug the hole. If you want to get fancy you can also buy the proper thermactor plugs but a bolt works just fine too.
    Cheers
