Results 1 to 6 of 6
    Default Found a build sheet of a 79 in a repair manual.
    Bought parts for fetching up my 79 Ghia.
    Anyone interested in the old build sheet I found?
    Hans.
    Mine is missing. Is this where it ended up?!? Seriously though, I am surprised that the build sheet in my untouched 79 is missing. I assume the PO must have pulled it out
    Boy, I never thought about looking for it in my untouched 79I own for 11 years already.
    You may not find them anywhere in the interior. They were not supposed to be left behind. But sometimes it could not be helped because pulling them out was impossible (behind the installed dash, above the installed gas tank, between the front lower seat cushion and springs, etc). Other times it was faster to pull them off a sub-assembly and throw it on the floor of the interior, instead of getting out of the car and going to a trash bin, because you have a job to do in a very short time window.
    Hans, if you post a bigger pic I can decode it for all to see. Otherwise you can mail it to me. Send me a message if you want my address. Thanks.
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    FoxChassis,
    Here 's the scan I made.
    I also dug under my own seats; no paper found there. Too bad.
    The parts I bought are red/ brownish. Curious what you find when decoding.
    Regards,
    Hans.Name:  Scan0011.jpg
Size:  53.9 KBName:  IMG_20181206_163523.jpeg
    Thats a little too small to be able to read the codes. I need a higher resolution.
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
