Results 1 to 13 of 13
    Default need help/advise on bad running 5.0
    I have a 1986 Capri 5.0 that I have been restoring. recently it has developed a miss in the engine and it is not just a single cylinder (checked headers with temp gun and pipes are all about the same). When you rev the engine (WOT) up it falls on its face and sputters until you let off the gas and then it idles fine. If you WOT it will just sputter until you let off the throttle ( could sputter for several minutes if you hold down the pedal WOT). I also noticed that all the plugs are black (way to much fuel). I have replaced the plugs, Brand new wires, TPS., Ign. module on dist.. I have noticed that when I do the volt test on the TPS the reading don't seem to change when I open the butterfly and I have put 3 different TPS sensors on it. Checked the ground on the engine harness too. The engine is all stock except a set of headers. Thank you for any input.
    1986 ACS McLaren Capri
    1971 Mustang
    1968 F100
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Two things I would look at.
    1- Troubleshoot the 5v circuit which feeds the TPS (and other sensors) and verify all is good. Until you have a TPS that shows changing voltage anything else is futile.
    2- If fixing the TPS hasn't solved the black plugs, take a look at the fuel regulator on the rail and verify the vacuum line is all good and the regulator itself is functioning correctly.
    '85 GT
    Portland Oregon
    I would also check for engine codes.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Quote Originally Posted by Tigger View Post
    Absolutely a wise suggestion!
    '85 GT
    Jul 2007
    Richmond, ME
    I'd look at the ignition coil too.
    I found a lot of good info from these sites
    http://www.veryuseful.com/mustang/te...ng-ECC-EFI.gif
    and the second post here
    https://www.stangnet.com/mustang-for...p-coil.784994/
    Barboursville, WV
    If your plugs look that bad, I can guarantee your O2 sensors are going to look bad, too. Probably cat converters dirty, as well.
    Is the engine completely stock? Maf conversion? Stock injectors? Have you checked fuel pressure regulator? All things I would look at.
    Barboursville, WV
    Another thing I forgot, what temp does it run? Does the engine temp stay well below the halfway mark?
    That sounds like what I went through on my 86. I replaced EVERYTHING I could think of and it turned out to be the distributor pickups were bad. That was on a rebuilt distributor! I replaced it and... runs like a champ, now.
    It could have been any of the sensors, plugs, wires, etc that I replaced in concert with the distributor, but that's how I finally figured it out.
    May 2016
    Lake City Pa 16423
    Is the 5 volt reference voltage reading 5 volts? That's what you should see going into the TPS. If you see battery voltage, you have a bad CPU ground.
    TPS is critical..... fix that
    also verify you are seeing advance at the distributor when you try to rev it. Use a timing light and watch the marks as you try to rev it up.
    verify your coil wire isn’t fried. Also that the rotor are good. Not new, good. Inspectcthe cap for signs of how the spark distribution is under the cap. I had one distributor wear out after around 430K miles and the shaft let the rotor go all over the place
    Make sure the advance spout and wiring is good. I’ve had one where it made connection but couldn’t carry enough current to actually advance the distributor on my 460. Talk about a truck that ran like crap!! It’s totally awesome now.....
    This¡
    The coolant temp sensor on the steel rail is mission-critical to these old systems. That's what triggers, partially, cold weather enrichment. If that sensor is sending faulty readings the computer may think it's fourty below and drown the engine in fuel. The air charge temp sensor can also cause this reaction from the EEC.
