We are in the process of a 7.5 to 8.8 swap. The car has a male rear brake line fitting from the hard line to the rear axle, the 8.8 has a female banjo fitting. Any ideas for an adapter to meet the two?
1985 GT Vert 5 Speed "Black B!#ch"
2000 V6 Stang 5 Speed-Sold
1994 Ford Bronco 5.8-Sold
2004 Nissan Xterra Off Road- Sold
2012 Mustang V6 6sp for the wife
2008 Jeep Wrangler JKU
You could just swap brake lines from the 7.5 and be done .
Yep, it'll still go around a reasonably sized dual exhaust, even with right side stock fitting/vent
If you want the newer style setup LMR sells the 86+ fitting. Also available in junk yard
afaik fitting was used well into the SN95 series
