Results 1 to 15 of 15
    Thumbs up 1980 stereo wiring= confusing!
    Ok I'll start this out by saying I thought I was clear and installed an aftermarket stereo and got the fronts working through a process of elimination. Now as i look to add rear speakers I'm getting confused and could use a little help.
    My 1980 came with an uninstalled factory Am/FM Cassette Stereo. Holy hell it was a challenge to physically get it back in requiring removal of several metal support beams and the center console. The wiring was plug and play though after some repairs to the original harness plugs but once all back installed I hated how it looked as the wood-grain bezel that was hacked to DIN and broken. Plus the original front 3.5's sounded awful and the radio reception not good.
    Can anyone confirm the following as other posts seem to indicate different wiring colors from what I have installed in this car. There is no center speaker and I don't think I saw a premium sound amp when I installed the dash pad.
    Other end of this power plug on the stereo has factory matched plug with the following
    Yellow with brown dots= 12V switched power
    Blue with red dots= Illumination?
    Separate wire hanging under the dash is a Black ground with ring that goes to the ground post on back of head unit.
    Left Front= white with green dots
    Right Front- orange with green dots
    black= common ground
    Right Rear- Green with Orange dots (negative?)
    Right Rear- Orange (positive?)
    Left Rear- Pink with Blue dots (negative?)
    Left Rear- Grey (positive?)
    I ended up temporarily putting an old Kenwood KRC-2000 in because I wanted something a little bit nicer but still reasonably period correct. I will keep the factory wiring in tact and may eventually try to run the factory unit again later. Thanks to other post suggestions I'm picking up a pair of new Pioneer 3.5's for the dash and 6x8's for the hatch and will call it good.
    I still need to understand the wiring before my final install so I get the phasing right and label everything for the future. I'm unclear if a speaker wire with hashes/dots are positive or negative. I think negative- is that right?
    Is the dash factory plug Blue with Red dots for illumination, a ground, or constant power for memory (not that there was such a thing for 1980 factory systems I imagine!)?
    Is there an aftermarket harness I can buy (nothing on lots of searches and Crutchfield guy said not available) that will plug in to the factory plugs so I don't have to hack into the factory wires?
    Appreciate any input/confirmation to guide me in the right direction!
    Current FEP:
    Past FEP:
    FWIW the Kenwood KRC-2000 wiring is as follows:
    Yellow : Battery - should have a 1A inline fuse - (memory)
    Red : Ignition - should have a 3A inline fuse - (power)
    Light Blue : Power antenna
    Black : Ground (chassis)
    Green : Left Front Speaker
    Orange : Right Front Speaker
    Blue : Left Rear Speaker
    Red : Right Rear Speaker
    Gray : Common ground for all speakers
    Current FEP:
    Past FEP:
    I do know that on my Zephyr the radio connector had a switched power wire and an illumination wire.
    Matt
    Great thanks for confirming! Must be that Blue with red dots is illumination. I cant find my wiring book ATM so will dig around for it.
    Current FEP:
    Past FEP:
    Found the book!
    Illumination
    [/url]
    Light Blue/Red is illumination @ 205 plug which is shared with the Switched 12v Yellow/Black Hash (it's not brown!)
    Stereo
    Confirms my colors are correct @ the speaker locations although maybe I'm going slightly color blind as I mistook black for brown or brown for blue on a couple. I assume the common wire that is shared with the speakers is the negative side is that right? So as an example that left rear speaker the Pink/Light Blue Dots would be the common/negative speaker pole. Do I have that right?
    Lastly then just need to find the speaker harness adapter to connect my speaker wire plug C238 to my Kenwood speaker wires.
    This 5 wire one on the left...
    Nothing comes up when I search for this...anyone have luck finding one?
    Current FEP:
    Past FEP:
    EVTM shows radio illumination and power connector C205. Two wire. The black and blue in above pic.
    The speaker connector is 5 wire, connector C238.
    Harness connector, body side, looks to have two separate feeds wired into the connector plug at C205.
    One is lb/r wire from fuse block position 13. Connection at C205 to radio pigtail blue wire for light bulb
    One is y/blk hash wire, from fuse block position 10. Connection at C205 to radio pigtail black radio power wire.
    Correct about the ground wires. Common/negative/ground. Black.
    Could find matching body side pigtail for the Kenwood speaker connector. Maybe they are around or generic.
    The worst is to have to cut nice factory wire connectors off to splice connections, except salvage yard or junk radio.
    Prob wind up cutting off the Kenwood connectors and hard wire as needed.
    But what to do to connect to the other end, the factory body speaker harness connector? Cut it too?
    I left the factory harness in place and wired new larger wire for all speakers and power.
    More work, but so are wiring adapter kits. Now have simple connection at radio. Plus for high power 4 ch amp.
    Now can interchange radios, using electronic mid 80's-90's factory Ford radio heads that have removable pigtails.
    The factory vinyl wires are 35+ years old. The color coding on exposed wire fades over time.
    Also found trailer wire light pigtails, wire kits, useful when fabbing up new custom wire circuits that can be disconnected easily.
    Like when removing the radio.
    Always a great resource GR thank you for confirming and the additional suggestions! Since I can't seem to find an aftermarket direct connect solution I'll probably tap and run new wires so I have the option to go original if I want to.
    Sometime I'll find a radio in the junkyard and snip those connectors off and pick up the rear speaker OG connectors to boot! I may pick up a Scosche FGA Floating Ground Adaper as it appears to simplify the install if I opt for a more powerful/modern head-unit. I don't need one for this Kenwood as it has the same 5 wire speaker setup.
    I posted all this up here not just for my own understanding but hopefully help others with the same 79-81 wiring questions.
    Current FEP:
    Past FEP:
    Yah thought about so much posted detail may be better via PM but others may need to know too.
    Not yours- mine. Maybe my new years resolution- not talk so much.
    Pages in chapters of a story. Plus they would have kicked us off by now if too boring or something.
    Hard to be brief documenting detailed thought process to help understand the what how and why that is found.
    The 80 EVTM did the trick. 79 is same but coded a little different.
    Could use 3M Scotchlok blue taps and jumper wires on radio harness connections.
    Bulky but no cutting and work fine when installed correctly.
    Should see my extra wiring. The aux radio amp has RCA jacks so used them when possible. Plug and play at that spot.
    So much extra acc, installed another fuse box and ground bar behind glove box in 2005. Took a load off the main.
    12v relay switches panel on/off with ign. Is wired 10 gage to battery thru a 30a maxifuse under hood.
    Runs radio, 2 aux 12v power points for seat heater and gps, 4 ch amp.
    Has room to power one of those air fuel things someday..
    Attachment 125252
    The hardest part of new wiring is the dash end. The speakers and radio. I leave extra wire at radio for better access later.
    Running wire to rear is easy to route to and behind pass kick panel trim, under pass door sill, into 1/4 trim to back.
    Can sneak it past rear seat bottom without removing (easier if removed), keeping wires away from pinch point at seat back lower side hinge.
    Ran both L and R rear wires under sill then branched them under rear seat.
    Front and rear speaker total is 10.
    Awesome job GR! Looks like you planned this out well with room to grow as needed. Thanks for sharing.
    Current FEP:
    Past FEP:
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Looks like you may have had your questions answered.
    I had upgraded and installed a similar unit in our 79 that never had speaker wiring and originally no radio.
    May be of slight help or just additional reading pleasure:
    http://vb.foureyedpride.com/showthre...I-do-with-this
    Thanks. Looking at my 1980 fuse box diagram it looks like there are empty (not used) fuse locations such as 3,9,16, & 17. Do you know if any of these unused ports already have switched 12v power based on experience? I'll test light and report back if nobody knows!
    Current FEP:
    Past FEP:
    Per 79 EVTM, 1,3,4,6,9,16,17 are unused. Looks like same for 80.
    Checked mine long ago seeking new unused circuits. None.
    Could tell right away looking into a open fuse position with a light..
    No contacts for fuses or no wiring to it at all.
    If there were, where did the wires route to?
    Add-a-fuse taps work, but have limitation of side clearance from other fuses and fuse box cover lid clearance.
    Have one in my truck for powering the added backup alarm with switch. Barely fit but did.
    Ok thanks GR I have taps on order
    Current FEP:
    Past FEP:
    Speakers went in very Easy without any cutting needed:Pioneer TS-A878 3 1/2" 2-way fronts & Pioneer TS-A6886R 6" x 8" 4-Way for the rears
    I confirmed + and - connections at the speaker and wired/soldered/heat-shrinked everything in however I don't get sound from the rears. I feel a bit dumb posting this but will try anyway short of running new rear speaker wires back to the rears. I did test wires directly to the rear speakers to confirm they work fine but for whatever reason it does not work through the factory rear wires. A correction to my above post on the wires for my KRC-2000 is that there is an extra common (ground) wire White so it should now go as follows:
    KRC 2000 Head Unit wires
    White: Common ground --
    Green: Left Front +
    Blue : Left Rear +
    Gray : Common ground --
    Orange : Right Front Speaker +
    Red : Right Rear +
    The fronts work fine when I wire all the black Ford wires together and run them to the Grey wire. I then tried touching the white common ground wire to these and still get no sound. The rear wires change color before they get behind the console to the factory wire plug (see Green wire comment below). I am tapping in before the plug. So either there is a break from the rear wires to the front or merging the common grounds all together with both the white and grey grounds causes a problem. Should I split the common grounds apart front and rear? Suggestions?
    Here is what my wiring looks like at the moment with rears not working.
    Current FEP:
    Past FEP:
    FYI I found my rear speaker wires had a cut along the way before the dash and were dangling. Running new wires from there fixed it and I have tunes although need to work on streaming improvements over the cassette adapter!
    Current FEP:
    Past FEP:
