Results 1 to 3 of 3
    Jul 2016
    Duncannon PA
    Default Rear upper control arms
    So I have a pair of brand new upper control arms that were given to me years ago. I never had a reason to use them til now. I'm thinking that while I'm under the rear of the Saleen putting in the Eibach springs and shocks that maybe I should put them in too. I understand that replacing the rear lowers works as good as a set of quad shocks but what about the upper.s?? It seems a lot of people only do the lowers. Why???
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
    When it comes to suspension and expert opinions I always go straight to Maximum Motorsports website. The info is presented in small nuggets which is great for me with a short attention span lol.
    If running the stock setup, then the only upper control arms you want to use are the OEM Ford stamped steel uppers with GOOD RUBBER Bushings. Any of the boxed, tubular, etc. arms with poly bushings will cause binding in the rear suspension and adversely affect the handling.
    I highly recommend the Maximum Motorsport lower control arms if you want to make a suspension improvement/upgrade, otherwise stick with the stock OEM lower control arms too IMHO. Others will disagree in regards to some of the other rear lower control arms available and some of them are better than others, but still for my $$ you can't beat the quality of the MM stuff. Good Luck!
