Results 1 to 4 of 4
    Default 351W swap headers question
    Need some help on deciding on long tube headers for my 84. Looking for 3 inch collector and something that will fit easily in with upr k member, afr 205 rengade heads and c4 trans. Car is almost out of paint and putting motor in soon. Thanks appreciate the help!
    I am no expert on the 351W swap, but I have done one in the past.
    Generally a tubular K member will give more clearance than the stock K member, so that shouldn't be an issue, but I you might check with UPR and/or the header manufacturer to verify if there are any issues.
    In my research the transmission seemed to be the biggest issue in regards to clearance. So keep that in mind. I have no experience with the AFR heads, so not sure what difference they make in regards to fitment.
    If working on a budget, I would seriously look at BBK first, MAC headers might be an option but iMHO their finishes are not the best, unless they have improved over the years. Obviously if $$ is not an option then Kooks probably either has or can build you exactly what you want/need. Good luck!
    I've used Hooker and Dynateck 351 swap headers before. The Dynatech headers were better, but run about $580 a set. Stepped tube 1 3/4" to 1 7/8". There are on the car in my build thread about my 1979 coupe. I did have to modify the drivers side to work with my 4r70w trans, an AOD would have the same issue. Manual trans should fit fine.
    https://www.summitracing.com/parts/d.../model/mustang
    The Hookers were Supercomps, they used adapter plates to mate to standard exhaust bolt pattern heads. The adapters were a pain to seal up properly.
    On a different build I had the K-member spaced down 1" for hood clearance. Just for the heck of it I tossed on a set of Flowtech 302 headers. They fit great, plenty of room, but the matching H-pipe would probably need to be modified. I just mention this in case you had a set of nice 302 headers laying around.
    Jess
    Previously owned;
    Thanks for the reply’s. I still have some time, my car is in paint at the moment and won’t have it back for another month. just don’t wanna get stuck with headers I can’t use. I’ll make some calls and see what they say also. Thanks
