Results 1 to 3 of 3
    Feb 2018
    Saskatchewan, Canada
    Default Brake caliper pin question
    Hey guys, just finished putting new calipers on my 84 and had a question regarding greasing of the guide pins. I used lucas oil heavy duty bearing grease on the pins and wondering if that would be alright. It's a polyura based grease meant for high temp brake applications. Was reading after that some grease can expand and deteriorate the rubber causing problems. Will I be alright with this? Thanks
    Pic for attention. I know some people laugh at painting calipers red but that's what the son wanted lol
    Attachment 125077
    Mustangs
    84.5 Gt T-top
    85 Gt
    Jan 2011
    Vancouver BC Canada
    I use the whitish clear grease that is specifically designed for caliper slides.
    Feb 2018
    Ya, I realized after that there is specific grease for them. Just did not realize before hand. Thought bearing grease designed for brakes would be ok. I guess question is should I take everything apart and redo with specially designed grease or will the stuff I used be sufficient.
    Mustangs
    84.5 Gt T-top
    85 Gt
