New User
Motor mount help needed
So I have an 85 Capri TTop roller and an engine from an 88 GT I am getting ready to drop in. However, when I try to purchase motor mounts, I have the option of either hatchback or convertible mounts. Just want to make sure I get the correct ones since no one seems to know at any of the parts stores which category to put the t top cars in. Thanks in advance.
Either will work in your car but the Convertible mounts are a better design and lower the engine about an inch.
I always just buy Convertible mounts regardless of the body style
New User
Convertible mounts are one piece, all others are 2 piece, 1 piece you can buy, the other you can't. So if you didn't keep the top part of the mounts for the 88gt, then it's moot. If you did then buy both, use which ever fits the best.
Energy makes poly mounts which work fine, too
- You may not post replies
- You may not edit your posts
Forum Rules
