Results 1 to 6 of 6
    New User
    Oct 2018
    Chippewa falls wi
    Default Blower motor removal
    Hey guys. I done the search and came up with 0 helpful info. My 85 needs a new squirrel cage. The blower attaches from the rear and not the bottom/front like what ive been reading.
    Does the dash have to come out for this? Cant get enough room loosing the front where the ac blend door is to access the cage.
    The blower motor has to come out towards the front of the car. No other way that I have ever seen. So yes you will have to at least loosen the dash enough to swing it on the passenger side away from the windshield in order to remove the HVAC box.
    Once removed you can remove the 4 screws (IIRC) that hold the blower motor in place. Then you can remove the squirrel cage from the motor itself. Not as bad a job as it sounds, but if you have never done it before it can be a bit daunting. Do a search on the site as a couple of members have posted the removal process here on FEP. Good Luck!
    New User
    Oct 2018
    Chippewa falls wi
    Thats kinda what i was thinking was gonna have to happen. Guess ill be buying a torpedo heater for the garage cause its COLD here. Thanks for the reply
    Been a while since I did one. I thought the heater box was split there and you can unbolt it from the "main" section and pull it right out from under the dash don't you? I swear I had done that without touching the dash but I am old now.
    New User
    Oct 2018
    Chippewa falls wi
    I do remember that it is split but there is a tucked away bolt i cant reach with the dash in the car due to a “tab” blocking access to it
    The more I think about it I KNOW I have done this. The last time was on a '92 a few years back. Take the glovebox out and there is (as you said) a mounting tab with a 8 or 10mm bolt up behind the dash. Take that out and I know for a fact I replaced the blower motor in that car with only removing the glovebox.
