Results 1 to 9 of 9
    Default Z51 Calipers SN-95 Spindles
    anyone heard of or done this? putting vette z51 brake calipers and pads onto sn95 spindles with 13 inch rotors? what you think?
    thank you!
    You'd have to some research and compare specs, but I believe some year Corvettes used the same 13" PBR caliper as what came on the SN95 Cobras. I'm not sure if piston sizes are the same or if the caliper bracket has the correct offset.
    I think I'd just as soon look for a set of used Cobra or Mach 1 calipers though.
    Thomas
    I just bought the cobra PBR calipers form Advance auto. Unless you could get the vette calipers for free or very cheap, I don't see why someone would bother too.
    Jess
    Previously owned;
    Dec 2006
    Greensboro, NC
    I'm in the process of rounding up all the parts for the Cobra conversion on my '85 GT. What's the best deal on front and rear calipers? I've had great luck with Centric rotors, so I'll probably get those from Rock Auto. How is the finish on the calipers from Advance Auto? Have any of you used a high temp paint that lasts?
    My photo website:
    http://www.twilightphoto.com/
    I used no name drilled and slotted rotors from ebay. Finish was good on the calipers, I used rattle can primer and brake caliper paint. I didn't have any issues with it coming off. Caliper brackets were the hardest thing for me to track down.
    Jess
    Previously owned;
    Grand Rapids, MI
    Quote Originally Posted by 854vragtop View Post
    Raybestos FRC-10604N and FRC-10603N for front calipers and brackets are the best price I could find. These are new and not rebuilt if that is important to you. Obviously they won't say COBRA or have a running horse on them. I'm just going to run GT/V6 rear calipers and brackets that I will rebuild for now. The rear calipers are all the same between Cobra/GT/V6. It is the caliper bracket that is different. The Cobra version should be slightly more rigid and is wider to accommodate the thicker vented Cobra rotor. You can grind the GT/V6 caliper bracket so it clears the thicker vented Cobra rear rotor. Obviously you will need the axle mounting brackets for the larger Cobra rotors.
    I too have had good luck with Centric C-Tek rotors. I use them on a ton of cars and have had no issues.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    I used the power stop kit from rock auto. I got reman ford calipers powder coated red and drilled slotted rotors
    Nov 2014
    Grand Rapids, Mi
    I just got my Cobra calipers from Napa. Good price. The rear cobra brackets off of amazon. The cobra brackets just look better imho.
    Mar 2013
    Where the Navy sends me...
    I've used a couple different types of caliper paint. The best success I've had is with G2 caliper paint.
