Hey all,
I have the MSD6AL-2 in my Fox and everything works great. I want to wire up the 2 step and I thought I had a plan but now I'm not sure? I've done a bunch of research and was going to wire everything up per this diagram....
My question is... I was going to wire pin 86 on the relay to the clutch switch as the diagram shows however I'm not positive that the 85 with a manual has the same type of clutch switch as the 86-93 does? The way the system is supposed to work is to push the clutch to the floor, press the momentary button and the two step will be armed. Once you release the clutch to launch, the 2 step will disarm and down the track you go. Thoughts? Thanks!
