Results 1 to 7 of 7
    Default 2 Step. 85 Fox with manual trans.
    Hey all,
    I have the MSD6AL-2 in my Fox and everything works great. I want to wire up the 2 step and I thought I had a plan but now I'm not sure? I've done a bunch of research and was going to wire everything up per this diagram....
    Name:  Screen Shot 2018-10-29 at 10.38.01 AM.png
    My question is... I was going to wire pin 86 on the relay to the clutch switch as the diagram shows however I'm not positive that the 85 with a manual has the same type of clutch switch as the 86-93 does? The way the system is supposed to work is to push the clutch to the floor, press the momentary button and the two step will be armed. Once you release the clutch to launch, the 2 step will disarm and down the track you go. Thoughts? Thanks!
    Thanks but it doesn't really address my question. My car is an 85. The 86 and up have computers. Is the clutch switch the same and does it operate the same in my 85 (non computer car) as the 86 and later? Thanks!
    Take a pic of the switch , it should have two connectors attached.
    86 coupe
    1993 GT
    My 10 Sec street cars
    Quote Originally Posted by srad2drag View Post
    Take a pic of the switch , it should have to connectors attached.
    Quote Originally Posted by dagassa View Post
    Its the same as in my 86..
    A buddy of mine wired my 2 step the way its layed out in the diagram. My process to engage the 2 step is click my button first to arm it. Then proceed to depress the clutch. Once the clutch is released, the 2 step is off.
    86 coupe
    1993 GT
    Thanks! Thats how mine is wired. Problem I was having is that the 2-step would arm but it stayed latched when I released the clutch. I was getting voltage coming back so I installed a diode and it works perfectly! :-)
    I just buttoned everything up.
