Thread: Early Capri
    Default Early Capri
    Here's a very early capri currently on CL in greenville, sc.
    Mar 2013
    DENVER CO, the 303
    Medium Chestnut Metallic, interesting...
    that's quite a find really. You don't see many like it, that's for sure.
    VIN
    9 = 1979 model year
    F = Dearborn Assembly
    16 = Capri Ghia 3-door sedan hatchback
    F = 5.0L V8 engine
    607457 = 7,457th 1979 Mercury scheduled for production at Dearborn Assembly
    Door Tag
    Date - 09-78 = September 1978 scheduled build
    GVWR - 3903 lb/170 kg = gross vehicle weight rating
    Front GAWR - 2014 lb/954 kg = front gross axle weight rating
    Rear GAWR - 1819 lb/825 kg = rear gross axle weight rating
    F0012 = 12 lbs front accessory reserve load
    R0034 = 34 lbs rear accessory reserve load
    Exterior Paint Colors - 5M = Medium Copper Metallic
    DSO - 21 = Atlanta district sales office
    Body - 61H = Capri Ghia 3-door sedan hatchback
    Int Trim - FA = Edinboro cloth & Corinthian vinyl seating, low-back front buckets (F), Black interior trim color (A)
    A/C - A = factory manual air conditioner
    R - [blank] = no radio?
    S - [blank] = no sunroof
    Ax - B = 2.47:1 axle ratio, non-locking differential
    Tr - W = C4 automatic transmission
    MM = front springs
    MM = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
