Results 1 to 3 of 3
Thread: Stalling issue
    Default Stalling issue
    Hi I have my 84 gt turbo . The car idles and runs great while sitting . Take a trip around the block runs great , go to slow down
    just dies . The car will start right back up. Ive replaced tps set at 96 , changed tfi module , spark plugs fuel filter . Has good fuel pressure.
    Im kind of thinking pip module in distributor but I wanted to see what everyone’s thoughts are . Ive done allot of searching but havent read any to my specific issue
    Thanks in advance
    Tom
    Jan 2004
    Arlington Washington
    While probably not related to the problem most tps's like to run a bit lower like .90 If you ever end up with a high idle or hang idle that could be your issue. Have you ever set your base idle and timing?
    Taken straight from svoca....
    To set your base idle you will need to have the car running, at operating temperature, all accessories off.
    The next step is to disconnect the IAC (Idle Air Controller). The engine speed should slow to around 750 or it may stall. The proper setting is listed on the emissions decal (825-975rpm) on the cover of the coil.
    With the IAC still disconnected set the idle speed using the adjustment screw on the front of the TB. Operate the throttle a few times to make sure that it is set properly.
    Turn off the engine and reconnect the IAC and start the car. After a few minutes the idle should set itself around 950 to 1025 RPM. After doing this procedure, it may be necessary to reset the TPS.
    1982 Capri RS 5.0L
    Thank your response. I will give it a try and see if it helps
    Tom
