Page 3 of 3 FirstFirst 123
Results 51 to 71 of 71
  1. #51
    The rust appears to be surface only. I would wire brush it and then coat it with either Eastwood Rust Encapsulator, POR 15, or your preferred product. The heat from the muffler can cause condensation that can lead to rust like that. Shouldn't be too bad. Good Luck!
  2. #52
    I agree — no big deal.
    In my younger years a reply might have been .... (Sarcasm included) Oh no, better get the muffler out of there. Let’s hear it for straight pipes!
    All jokes aside they do sound awesome with no muffler and a turndown..... some prefer to add headers for added sound intensity even. But I’d never do it to a street driven car.
    Me personally, I prefer 86-93 style duals with a free flowing set of shortie headers, H pipe with cats, and some nice turbo mufflers like Dynomax or Magniflow.
    The thing you will want to watch is CA emissions requirements for your car. That will dictate what you can do most likely.
    Being SO preserves you’ll hurt the value if you make any changes that can’t be undone easily to return to factory. Save the pieces....
  3. #53
    VIN
    9 = 1979 model year
    F = Dearborn Assembly
    04 = Mustang Ghia 2-door sedan (coupe)
    F = 5.0L V8 engine
    172278 = 72,278th 1979 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 11-78 = November 1978 build
    GVWR - 3910 lb/1773 kg = gross vehicle weight rating
    Front GAWR - 2111 lb/957 kg = front gross axle weight rating
    Rear GAWR - 1819 lb/825 kg = rear gross axle weight rating
    F0000 = 0 lbs front accessory reserve load
    R0038 = 38 lbs rear accessory reserve load
    Exterior Paint Colors - 2P = Bright Red
    DSO - 15 = New York district sals office
    Body - 66H = Mustang Ghia 2-door sedan (coupe)
    VR - [blank] = no vinyl roof
    Mldg - 10E = Black bodyside molding with Argent inset stripes
    Int Trim - SN = vinyl seating, low-back front buckets (S), White with Medium Red interior colors (N)
    A/C - A = air conditioner
    R - 4 = AM/FM stereo radio
    S - C = sunroof
    Ax - Y = 3.08:1 axle ratio, non-locking differential
    Tr - 5 = manual overdrive (Tremec 4-speed 'SROD') transmission
    MM = front spring codes
    MM = rear spring codes
    Buck Tag
    MUSTANG = Mustang model line
    66H = Mustang Ghia 2-dr sedan (coupe)
    F = 5.0L V8 engine
    MR = moonroof (sunroof)
    137_ = body & paint rotations #137_
    2P = Bright Red exterior paint color
    W = White interior trim color
    ST
    M
    AC = manual air conditioner
    DRM = dual remote mirrors
    COM
    MOD = manual overdrive transmission (Tremec 4-speed 'SROD')
    1 = no hood scoop
    V = visibility (light/convenience group)
    4
    6
    Hey FoxChassis - Thanks for breaking the tags down for me. I am super curious how many other cars were made with these same options. I need to get a Marti
  4. #54
    Default 1979 Ghia Coupe Build Thread
    Duplicate
  5. #55
    I will do just that when I redo the exhaust. I am not going to worry about it now as our climate is mild here; no snow just cold rains for the winter
  6. #56
    Used a take-off late model Expedition resonator for the muffler. These are small bodied straight through design great for low cost, stainless construction performance. Accent is on low cost as this is temporary however it has a great deep tone. I have gone this same route on a prior car so knew going in that this is about the best sound and performance at THE lowest cost lol. I will post a sound clip this weekend.
    All updates to the car will be reversible and all parts kept excluding the muffler in this case. It was rotten inside with good sized hole on the belly
  7. #57
    New User
    Oct 2008
    Independence, MO.
    Any pics of the full car with the new wheels? Btw, what a sweet Looking car!
  8. #58
    Quote Originally Posted by johnnyj View Post
    I don’t have any good pics with the wheels on but will take some when we get a break in the rain. Thanks for the compliment
  9. #59
    Sorry guys haven’t posted in a while. Here’s some updates pics of the Ghia coupe.
  10. #60
    Looks fantastic!
  11. #61
    Very sharp. Who did the center caps for you? I have those wheels on my 87 Tbird & have always wanted caps with the Bird emblem.
    Ray
  12. #62
    Apr 2016
    Sprague River, OR
    I think I've seen this car on Instagram?
    Join The Conversation
  13. #63
    Quote Originally Posted by ISTLCRUZ View Post
    Ray
    Check out Tom via Insta https://instagram.com/sinisbuilt?igshid=xdlpgygtdfp3
  14. #64
    Looks fantastic!
    Thank you
  15. #65
    Yessir! We gotta get our foxes together. Maybe I’ll tow it up with the F150 when we do the wrap
  16. #66
    Dec 2009
    St. louis MO
    Quote Originally Posted by saleen428 View Post
    I have started to order parts and here is one of the first that arrived. Not anything that would cause a lot of excitement but I get to check one of the cells in the project spreadsheet lol
    Nice '79 coupe, but I'm partial to them. These emblems are like gold now for what they cost. I'm really surprised they haven't reproduced them like the '82 GT emblem.
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
  17. #67
    Quote Originally Posted by STL79Coupe View Post
    Its interesting because that emblem used to be available all day with virtually every vendor at reasonable prices and the 82 GT emblem was the Unicorn that fetched big $$$. Now just the opposite! My guess is there were enough OEM NOS emblems around that there was little need to reproduce the Tri-colored emblem. Hopefully they will address it in the near future. I would really be happy to see more of the early 4 Eyes stuff begin reproduced instead of all the Aero model stuff. I think they might be surprised how well some of it may sell if done right. Oh well, off my soap box again.
  18. #68
    Dec 2009
    St. louis MO
    I agree totally Trey. I have one NOS emblem of each waiting for a car to restore someday.
  19. #69
    Thanks brotha. Not sure when it’s going to go on. I am undecided on whether or not to have it painted next year. More and more I appreciate the original paint and it’s worn spots.
  20. #70
    Need help with red interior color code for paint/dye. My Int Trim - SN = vinyl seating, low-back front buckets (S), White with Medium Red interior colors (N). I called NPD and they do not have anything listed for 'SN', but they do have Medium Red for: 1979-1979 MUSTANG W/ INTERIOR TRIM CODE *AD*, *LD*, *BD*, *MD*, *AN*, *LN*. LMR's product listing states 82-83 and does not include 79. What have yall used that is the best match?
  21. #71
    1979 Mustang seat type codes (1st character of the "INT TRIM" code on the door tag)
    A = all vinyl seating, high-back front buckets
    B = cloth & vinyl seating, high-back front buckets
    C = all vinyl seating, low-back front buckets, with interior accent group
    D = cloth & vinyl seating, low-back front buckets, with interior accent group
    E = leather & vinyl seating, low-back front buckets (Ghia only)
    F = cloth & vinyl seating, low-back front buckets (Ghia only)
    L = all vinyl seating, high-back front buckets (Cobra only)
    M = cloth & vinyl seating, high-back front buckets (Cobra only)
    N = all vinyl seating, low-back front buckets, with interior accent group (Cobra only)
    P = cloth & vinyl seating, low-back front buckets, with interior accent group (Cobra only)
    Q = leather & vinyl seating, low-back front buckets, with interior accent group
    R = leather & vinyl seating, low-back front buckets, with interior accent group (Cobra only)
    S = all vinyl seating, low-back front buckets (Ghia only)
    U = Recaro cloth & vinyl seating (Pace Car only)
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
