Page 1 of 3 123 LastLast
Results 1 to 25 of 51
    Default N/A 3.8 CFI woes
    For the last two weeks i've had a significant issue with the car. It'd run lean and deeply limit my speed.
    pulled codes twice: big ones were things to do with the EGR and cylinder 1 being low during the balance test.
    First thing was to clean the EGR... did that and may have forgotten to hook up the vacuum line going to the EGR. it seemed good for about an hour of driving to get to school. Car stalled out twice at two red lights due to a SUPER low idle. But that was the only issue for the most part that day. Only drove it to school and home that day, let it sit over the weekend.
    Sunday night, dad noticed I didn't hook up that vacuum line, hooked it up for my while we were adjusting my idle.
    Monday morning, I was driving to my vocational classes to take care of another small thing with the car and about three miles into the trip I went from 45 mph down to 30 almost immediately with no change in throttle input, at that point the car was warmed up. Turned around to get to my own school, couldn't get past 30 mph.
    My dad and I are stumped on this one. We haven't been able to figure this one out.
    Ray
    1986 Mustang "Frankenstang"
    1997 Crown Victoria
    Quote Originally Posted by 86frankenstang View Post
    by this I mean that we aren't looking to spending $80 to buy a new EGR just to drive the car for another week.
    Ray
    1997 Crown Victoria
    So I understand it's way down on power but are you saying you think it would run fine to California as long as you stayed under 30MPH? How did you arrive at the theory that it "runs lean"? Does it idle at all? Does it start and run fine with your foot on the gas but then lose power when put in gear? Can you rev it up freely in neutral at all?
    You can use a piece of tin to block off the EGR for free. An EGR is not capable of making your car not be able to go over 30. A bad EGR will cause surging, poor idle, possibly off idle stumble etc. but you would be able to go as fast as you wanted.
    Pulled spark plugs last week. With what I know, those engines run on loops, it'll start and run fine until it gets up to temp when the ECM actually starts reading and adapting to what the sensors are telling it. I wouldn't trust it to drive all the way to California.
    Last week the idle would stumble in park, haven't noticed it at all this week.
    and here's your checklist: Starts fine cold without foot on gas, power loss in gear (will be checking trans fluid again in the morning), can rev freely in neutral. does tend to surge when i get to the speed it seems limited to.
    Ray
    1997 Crown Victoria
    Your issues are the EXACT reason I am getting rid of the damn fuel injection system on my 86 convertible. That damn thing is the root of all my problems. good riddance to it!!!!
    little update: took it down the road and back after having it sit in my driveway for about a week, doesn't rev freely in neutral, seems to build a misfire at around 1500 rpm, can't get past 25 mph. Luckily i'm trying to get her in my school's auto shop for the winter so i can do my 5-speed swap in comfort, I've got a spare 3.8 coming my way soon and will probably start swapping parts if needed.
    Ray
    1997 Crown Victoria
    Plugged exhaust?
    '95 Saturn SW2
    Coil I bet.
    Comp cams XE254H, hypereutectic pistons, catted BBK H-pipe, full custom duals.
    I say that because anything that would make the cfi cause that problem would throw codes.
    there are the codes from my last check.
    Ray
    1997 Crown Victoria
    yeah, but those codes don't make me think of the symptoms you are describing. If those were causing your issue, disconnecting the egr would actually fix them.
    although that last one might be important.
    And the odd cylinder count I don't understand but could imagine a coil or cap and rotor might influence.
    I ran the test twice, same codes. did disconnect the vacuum line going to the EGR and plugged it with something, didn't solve the problem.
    If i can get it in one of the vocational auto shops in my area that would be ideal, but so far it's looking like i won't have much luck doing that,
    Ray
    1997 Crown Victoria
    Coils are so cheap, give it a shot. Check that cap too, look to see if there is bad wear patterns on the contacts.
    Time to revive this thread as spring is rolling around the corner.
    I haven't given too much thought to the problem other than coils. Dad said he replaced all of the ignition components when he did the rear end swap and can't see that being the problem.
    We did have an ongoing loss of coolant shortly after replacing the radiator, did a system pressure test awhile ago and had coolant leaking from the top of the timing cover, but that's the only time i ever saw coolant leaking from there. I checked under the car everytime I parked and everytime I came back to it, only saw a puddle once, and it didn't appear to be coming from the timing cover.
    The engine was rebuilt about 28k miles ago, so I don't see how the bottom end spontaneously failed.
    Jul 2009
    Chicago, south subs
    tfi or distributor module? Also, with cars of this age, vacuum lines and electrical insulation can be very brittle/deteriorated causing vacuum leaks and electrical shorts. I mentioned all of this because my '86 LTD has suffered from all these things. It was dying randomly at stop signs/lights (at idle with brakes applied) and eventually wouldn't start at all. A used distributor from the j/y solved that. I have also repaired several vacuum lines and crumbling insulation. Good luck figuring it out.
    Dec 2013
    Connecticut
    I don't remember the check engine light coming on, but driving my 86 3.8 after a 15 year nap
    it started running real stupid , no power, and not shifting right.
    I found one of the plugs on the vacuum tree had rotted and split.
    97k and no issues with the CFI.
    Ray
    86 Mustang LX 3.8 Convertible (bought new
    84 Capri (needs help)
    05 Volvo XC90 DD( The Swedish Tank)...................Used to own
    08 Magnum (The Roadie Wagon)...........................Too many. the good ones
    95 Saturn SL2 (Kid's Ride).................................65 Chevelle SS, 69 Torino GT
    94 Saturn SL2 (now parts for above) ................39 Willys Overland, 69 Fleetwood, 86 Saab 900
    65 Galaxie 500 XL 390 auto (Waiting for funds)..81 Mustang T-Roof hatch, 88 Lincoln LSC,
    How old is the o2 sensor? how is the o2 sensor wiring?
    might be original, i don't really know, i'm suspecting it's something exhaust related tho
    Ray
    1997 Crown Victoria
    it's got a distributor, been wanting to look at the vacuum lines for awhile too
    Ray
    1997 Crown Victoria
    I think he may have been referring to the pickup coil in the distributor when he mentioned distributor module. I had an issue where my car would just stall going down the road. Once it sat and cooled down it would run fine for a while and then do it again. Replacing the ignition module had no effect. I wound up just replacing most/all of the ignition because the problem was very difficult to reproduce. Part of that was a new Motorcraft distributor with the aforementioned pickup coil. I cannot recall from your other posts what all you have done on the car to try to solve any other issues.
    '95 Saturn SW2
    i haven't done anything to the motor besides rebuild the TB and replace injectors. we had a short in the ECM and soldered wire to bypass that short, have an ECM on hand in case i need it though.
    Ray
    1997 Crown Victoria
    This is what I put in my car. Dirt cheap for what it is in my opinion.
    https://www.rockauto.com/en/moreinfo...133862&jsn=467
    '95 Saturn SW2
    There's a long list of parts that -might- cause your problems, so replacing parts in hopes they might fix
    something is pretty likely to only lead to frustration. You need to follow the data.
    Have you considered checking the fuel pressure? CFI is pretty picky about fuel pressure, and you've got
    codes saying it's running lean. Should be 35-45 PSI, but most run best between 39 and 42. If the pressure
    is low, you might try a new fuel filter, otherwise you need to diagnose why the pressure is still low. This
    could be a voltage supply problem, a grounding problem, or the main or in-tank lift pump may be failing.
    The EGR codes are all complaining about the position sensor. But don't reach for a new one just yet. If the
    valve is not seating, you need to correct that condition. But the 31 code suggests that's not the issue.
    Whether or not the valve is seating, you need to understand why the EGR valve position sensor is out of
    range.
    First, measure the resistance between the EGR position signal pin, which is the one next to the flat on the
    connector (Brown/Light Green wire) and sensor ground, which is the connector pin opposite the signal pin
    (Black/White wire). With the valve at rest, the resistance should not be greater than 5500Ω. Using a hand
    vacuum pump, or by mechanical means, gradually operate the valve. The resistance should smoothly
    decrease to no less than 100Ω. At no point in the valve travel should the sensor resistance read open.
    If that checks out, measure the voltage between the VREF pin (orange/white wire) and sensor ground
    (Black/White wire), with the key on. You should have between 4V and 6V. If the sensor voltage is low, try
    moving the sensor ground probe to engine or battery ground. If the voltage increases, you have a sensor
    ground issue. Most likely that would be the ECU ground pigtail connection on the negative battery cable.
    Cheers,
    Jeff Cook
    Does sound like the EGR is getting stuck open, but the EVP could be the culprit, I had that pair of valves on the drivers side fender apron get leaky and then would not control the EGR properly. My driveability issue with that never got this bad though.
    1985 LTD LX original owner
