Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
    There's a long list of parts that -might- cause your problems, so replacing parts in hopes they might fix
    something is pretty likely to only lead to frustration. You need to follow the data.
    Have you considered checking the fuel pressure? CFI is pretty picky about fuel pressure, and you've got
    codes saying it's running lean. Should be 35-45 PSI, but most run best between 39 and 42. If the pressure
    is low, you might try a new fuel filter, otherwise you need to diagnose why the pressure is still low. This
    could be a voltage supply problem, a grounding problem, or the main or in-tank lift pump may be failing.
    I've been suspecting faulty grounds for awhile now, replaced the fuel filter when we got the car out this summer so i'd say it's safe to rule that out. I don't know how old the fuel pump is either, i'll want to check that out soon enough. From what I remember, fuel pressure is fine.
    Ray
    1986 Mustang "Frankenstang"
    1997 Crown Victoria
    I added a couple of extra grounds, alt-firewall, intake to firewall and coil housing. I don't think they were really necessary, but it didn't hurt. Quick and easy to take out the EGR and clean it up, new filter, and check those electrical connections. That is if you feel good about your codes. You got some strange ones last time if I remember right. Have you checked them lately?
    Comp cams XE254H, hypereutectic pistons, catted BBK H-pipe, full custom duals.
  3. #28
    showed an abnormal cylinder count, Cyl 1 was low during the balance test.
    other than that it was just EGR, EGO, and system lean.
    Ray
    1997 Crown Victoria
  4. #29
    and i have not checked codes since then. started it up a month ago and heard a misfire, didn't take a look since.
    Ray
    1997 Crown Victoria
  5. #30
    went through all the ignition wires tonight and found two loose on the plug. did a KOEO check and got this:
    21: ECT out of range
    24:ACT sensor out of range (excl 1.6 PFI, 1.9 PFI & 2.3 T)
    31:EVP out of range
    figured i'd get her started and do a KOER test but my reader was being finicky and didn't want to do anything. or it just wasn't receiving codes.
    gave it a little gas and immediately started to miss and stall out.
    here's the next startup to get it in the garage. https://youtu.be/3J4nrG7F37w
    It was completely fine in reverse if i didn't give it any gas though. Makes me want to believe fuel pressure is the culprit.
    Ray
    1997 Crown Victoria
  6. #31
    The fuel map is basically based on the engine temps, you don't have a functional air temp or coolant temp.
    I would start there. Without those, it's never gonna rub right.
  7. #32
    Yeah, did you replace those already? My ect behaved badly because I assumed the tape it came with was there for a reason but it was causing a bad ground situation. Last thing I did before all my gremlins went away was the EC and ACT. That is why I did all the grounding stuff too. I thought it was a little suspect that every sensor on the intake manifold would suddenly decide to flake out. I replaced the EVP 5 years ago and that was throwing an error as well but I didn't bother replacing that again since I was rather sure it was grounding issues. All of those codes are gone now for me and the occasional whacky idle and bad running went with them.
  8. #33
    haven't taken a look at those yet, suppose that's also on my list.
    Ray
    1997 Crown Victoria
  9. #34
    got around to taking a look at the ACT and ECT today... they seem to be working fine but when we swapped the ECT with one from a spare 3.8 we have, it ran rich as hell.
    video for reference: https://youtu.be/fcCZFlm2SII
    did the same thing, soon as it was given gas, stalled out. starting to lean to the ECU being the problem again, i'll end up taking a look at it or swapping it with another spare i have soon enough.
    Ray
    1997 Crown Victoria
