Results 1 to 8 of 8
    Default Tips for lubricating an emergency brake
    Mine is very difficult to move and doesn't release after engaging unless you pull the rear brakes and yank on the cable. Any suggestions?
    Replace the cable(s).
    Since you are in NY, if they are sticky now, they will only get worse with rust. I would not consider it that bad of a job, get need to crawl under the car a bit. Much easier than a heater core.
    That doesn't seem like an easy job... Is it?
    You can try lubricating the cables themselves and see if that helps. Otherwise as mentioned replacement may be the better option.
    The job is not "easy", but not a terrible one either. Getting the cable removed from the backing plate and shoes is generally the biggest pain. A 1/2" closed end wrench is the best and quickest way to release the clips holding the cables into the bracket on the body. Good Luck!
    Are those 'brackets' the odd little crowns I see where the cables enter the body? I have that second fuel pump right where the passenger side enters the body too. I assume one of the 'ends' of the cables are detachable and you just pull it through? Pushing through the new cable is not a pain?
    Pretty sure the cable itself cannot be pulled out. The ends are crimped or something.
    Not that hard to replace assy. As mentioned, the rear drum end is the most time consuming.
    Looks harder than it is. Think i remember the backing plate clip was the hardest part.
    And of course the fun part of fiddling with drum brake parts.
    Disconnecting it will determine if the cable or other parts are binding up.
    Thing is, although less costly, lubing cable well- if even possible- would be as much work as replacing it.
    Parking brake is a safety item. Best if repaired correctly and used.
    If not used regularly, gets 'rusty'. Most just park in gear, park, or use a curb.
    And after learning about curb parking on San Fran hills with wheels turned.
    Had mine roll away unattended several times. Once, the Ranger rolled into the street. Think i learned? No.
    Not using it, afraid to use it now concerned it will stick and lock up the brake shoes.
    Kind of a dumb reasoning on my part. What if i really needed it?
    If not used when parking, does help to test from time to time in a open parking lot, just to see how well it works.
    No it wont lock brakes, spin the car out or stall it unless ratcheted on. Is a gradual slowdown, depending on adjustment at lever.
    Keep button pushed down during test so pb is free to control up and down by hand.
    Yeah, just ordered new cables. Going to have the shop do it, my time is worth more than that. The drums are all fresh rebuild. It is an auto, so I never used it and this is my reward.
    Yes, the little "crowns" are the clips that hold the E brake housing in place and the cable is able to operate inside the housing. Those are the ones I recommend the 1/2" box end wrench for removal. Once the cables are disconnected from the E brake handle and the drums, they are fairly simple to remove. As others have mentioned the drums are the largest amount of work.
