Results 1 to 4 of 4
    Default '85 Mustang GT ORIGINAL Vacuum/Emissions four solenoid module
Size:  113.1 KBEssentially, this module is about all I have left from my '85 Mustang GT. Surprisingly, my one part sales from this car often led to much larger sales to the same person. So much so that I now have very few parts remaining from this car. If you have any questions, I will do my best to answer them in the order that they are received.
    As I'm sure there's an official name for this item, I'll be darned if I know it. What I am sure of is it's in excellent condition and if you're on a quest to bring one of these cars back to its original condition, then you might be in need of it. In other words, it's $300 plus shipping.Name:  P1040679.jpg
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    FYI- That is a "High Altitude Compensation Valve Assembly".
    It worked in conjunction with a sensor located on the front of the drivers side strut tower and together, they would essentially cause a vacuum leak and lean out the mix at high altitudes.
    '85 GT
    Thank you! Tried to find in my shop manual. Now that I know its name, will take another look.
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    You'll find mention of it on pages 132 and 133 of the EVTM.
    Its also here on the under hood vac diagram off my '85 5 speed GT.
    Name:  hi alt vac diag.jpg
    '85 GT
