Results 1 to 3 of 3
    Default 85 GT Fuel bowl solenoid valve
    Reconnecting some emissions equipment that a previous owner removed on 85 GT h.o. 5spd Thanks for looking.
    My 1st question, is that I can’t find the factory ground attachment point for these ?
    They are attached to the front of the block and yes they both are attached using the same bolt. Before hooking anything up clean up both sides of each eyelit, the surface of the cyl block and the under side of the head on the bolt.
    Quote Originally Posted by JacksAO View Post
    Ok thanks looks like the alternator will have to come off to find it. I’ll check it out tomorrow hopefully.
