Any common problems with Ford cruise I should know about? Mine is not working. It's 1990 model year, but it looks to me to be the same sort of thing a 4-Eye would use. Vacuum diaphragm and all that.
My original thought was that it had something to do with my work on the car causing a connector to come unplugged or something like that, but now I'm starting to lean towards it being a normal failure. Connectors are plugged in, fuses are good, and module has power and ground in the correct places. And the vacuum lines are installed.
Any thoughts? Thanks in advance!
