Results 1 to 2 of 2
    Apr 2009
    Acworth, GA
    Default Looking for pictures of power steering lines without the cooler
    Hi,
    I've been struggling to get my stinger front mount installed since right in the middle of the return is the power steering cooler lines. I added this when I replaced the radiator support since the replacement had it. I've tried moving them, bending the bracket etc. and nothing is getting them out of the way.
    Looking at lots of other non-SVO 2.3 turbos I don't see that they had the cooler from the factory.
    So I want to remove mine and see if that helps with the intercooler fitment issues.
    How does the non-cooler lines run from the rack back to the power steering pump? looking at the hoses (before I take it apart) I don't see how not to kink the hardline out of the rack, or loop it right into the fan belts
    Chris
    Idk if it’s specific to the 4 cyl cars or not, but on my LTD LX it doesn’t have the cooler in the core support so it’s just a hose and a clamp going straight up to the pump
